PowerGenius XL
1235»
  • N6OIL
    N6OIL Member ✭✭
    edited April 2017
    Thank you Craig for the update, please don't be a stranger here, your insights and real life experiences with the Flex and PGxL are invaluable.
  • Bill Turner
    Bill Turner Member ✭✭
    edited April 2017
    Since a legal limit antenna tuner is about $1500, if it will tolerate SWR up to 2.5:1 that's pretty good. All  my antennas are below 2:1 on the frequencies I use. Thanks.
    73, Bill W6WRT
  • John AE5X
    John AE5X Member
    edited November 2019
    QSK on CW?
  • Rich - N5ZC
    Rich - N5ZC Member ✭✭✭
    edited October 2017
    Tim,
    What are the dimensions of the Amp including projections.  I'm going to build a shelf to slide under and need to know what the height is including feet. Looks like cooling is handled front to back so I shouldn't need much clearance on the top, correct?
    Rich - N5ZC
    edited April 2017
    The dimension specs are on the website.  On the back, I'd add an inch for the connectors.  Cooling is front to back.  Since the case is also part of the thermal mass of the unit, you will need some clearance on the top.  Probably a few inches.
    http://www.flexradio.com/amateur-products/
  • Rich - N5ZC
    edited April 2017
    Thanks Tim,
    So the 5" height spec includes the feet?
    Rich - N5ZC
  • Craig K9CT
    Craig K9CT Member ✭✭
    edited April 2017
    The Beta is 6.5" from the front feet to the top cover....but of course this could change in production.
    73, Craig K9CT
    edited April 2017
    Thanks Craig for the info
  • Ria
    Ria Member ✭✭✭
    edited April 2017
    I would be very surprised if it wasn't.
  • Rich - N5ZC
    edited April 2017
    Thanks Craig,
    Working on either a desk location or my rack, haven't decided yet.  There's pros and cons to both.
    Rich - N5ZC
