Feeding the audio output of multiple sliced to the input of a software modem.
W4NTG
I am trying to set up multiple slices on a 6k series Flex that will allow the routing of the audio outputs to the input of a software modem. This is for an ALE broadcast that occurs on sequentially by frequency. I use a broadband antenna and would like to do it without manual intervention
I am using PCALE with my Flex 6700 and scanning the Frequencies in one Slice with problems, sometimes the Mode changes from USB to LSB on the lower Bands (3 and 7 MHZ). So I need only one Slice. I am not sure if this is a bug in the Smart-SDR software.
Rudy HB9MHB
It is a deficiency in the PC-ALE software. It needs to issue a MODE command after each band change for the FLEX-6000.0
Tim, do you have any ideas on my original request...tnx ****
You can do it with DAX. Put a slice on separate DAX channels and use a software mixer to mix down to a single or pair of channels.0
Tnx Tim, unable to find a mixer that will handle more than 2 channels...for flex we need from 4 to 8 channles...additional thoughts?...****
How about turning on all the speaker channels and take a wire from the radio back into the mic input?0
VoiceMeeter banana? Virtual audio cable?VAC is more or less a staple of Flex users prior to the signature series.
Ria0 -
Tnx Ria, is it capable of more than two links...****
Tnx Tim, working through them...****
- 633 The Flea Market
- 131 SmartSDR+
- 197 DAX
- 42 Aurora
- 955 Maestro
