Feeding the audio output of multiple sliced to the input of a software modem.
W4NTG
W4NTG Member
edited November 2019 in FLEX-6000 Signature Series
I am trying to set up multiple slices on a 6k series Flex that will allow the routing of the audio outputs to the input of a software modem.  This is for an ALE broadcast that occurs on sequentially by frequency.  I use a broadband antenna and would like to do it without manual intervention
  • Rudy HB9MHB
    Rudy HB9MHB Member ✭✭
    edited April 2017
    I am using PCALE with my Flex 6700 and scanning the Frequencies in one Slice with problems, sometimes the Mode changes from USB to LSB on the lower Bands (3 and 7 MHZ). So I need only one Slice. I am not sure if this is a bug in the Smart-SDR software.
    Rudy HB9MHB
    edited April 2017
    It is a deficiency in the PC-ALE software.  It needs to issue a MODE command after each band change for the FLEX-6000.
  • W4NTG
    W4NTG Member
    Tim, do you have any ideas on my original request...tnx ****
    edited April 2017
    You can do it with DAX.  Put a slice on separate DAX channels and use a software mixer to mix down to a single or pair of channels.
  • W4NTG
    W4NTG Member
    edited April 2017
    Tnx Tim, unable to find a mixer that will handle more than 2 channels...for flex we need from 4 to 8 channles...additional thoughts?...****
  • Bill W2PKY
    Bill W2PKY Member ✭✭
    edited April 2017
    How about turning on all the speaker channels and take a wire from the radio back into the mic input?
    edited April 2017
  • Ria
    Ria Member ✭✭✭
    edited April 2017
    VoiceMeeter banana? Virtual audio cable?
    VAC is more or less a staple of Flex users prior to the signature series.
    Ria
  • Dick McNutt
    Dick McNutt Member
    edited April 2017
    Tnx Ria, is it capable of  more than two links...****
  • W4NTG
    W4NTG Member
    edited May 2017
    Tnx Tim, working through them...****
