maestro cant remember its settings
AH0U
I must tell Maestro every time I use it what software to use and what radio to connect to... I only have one 6700 and only use the one SSD program, why can't it remember that so I don't have to click on the 6700 and click on the software every time I use it??
For the record .. What version of flex SW are you running ? ANd are you using Wifi or wired ethernet?
AL, K0VM0 -
I believe this is normal. I have to do the same thing.
I also have to tell it what WIFI to hook up to. SSDR1.10.16
It is "normal", but a little aggravating for me, too. My SW selection screen is full of obsolete SSDR versions, and the current one is somewhere in the middle. (At least order them by date!) I agree the default should be "info last used", but then Flex needs to provide a way to alter the settings if needed. Especially if there is a new SSDR version or if the radio finder comes across a new radio.0
I use 1.10.16 which I believe is the latest I also use a cat5 cable to connect the Maestro to the 67000
- 383 Community Topics
- 638 The Flea Market
- 144 SmartSDR+
- 434 SmartSDR for Mac
- 273 SmartSDR for iOS
- 261 SmartSDR CAT
- 200 DAX
- 958 Maestro
- 57 FlexControl
- 934 Genius Products
- 342 Tuner Genius XL
- 303 Shack Infrastructure
- 142 Amateur Radio Interests
