maestro cant remember its settings
AH0U
AH0U Member ✭✭
edited January 2020 in FLEX-6000 Signature Series
I must tell Maestro every time I use it what software to use and what radio to connect to... I only have one 6700 and only use the one SSD program, why can't it remember that so I don't have to click on the 6700 and click on the software every time I use it??
  • Al K0VM
    Al K0VM Member ✭✭✭
    edited June 2019
    For the record ..  What version of flex SW are you running ? ANd are you using Wifi or wired ethernet?
    AL, K0VM
  • Norm - W7CK
    Norm - W7CK Member ✭✭
    edited April 2017
    I believe this is normal.  I have to do the same thing.
  • Mal
    Mal Member
    edited April 2019
    I also have to tell it what WIFI to hook up to. SSDR1.10.16
  • Martin AA6E
    Martin AA6E Member ✭✭✭
    edited January 2020
    It is "normal", but a little aggravating for me, too.  My SW selection screen is full of obsolete SSDR versions, and the current one is somewhere in the middle. (At least order them by date!) I agree the default should be "info last used", but then Flex needs to provide a way to alter the settings if needed.  Especially if there is a new SSDR version or if the radio finder comes across a new radio.
  • AH0U
    AH0U Member
    edited April 2017
    I use 1.10.16 which I believe is the latest I also use a cat5 cable to connect the Maestro to the 6700
