Power genius XL on 2 meters?
Ria
Member ✭✭✭
From here: http://www.4o3a.com/index.php/2017/03/13/the-bouvet-island-dxpedition-3yoz/ We are sponsoring the Bouvet Island DXpedition scheduled in early 2018. Bouvet is a 97% ice covered island in South Atlantic Ocean covering about 19 square miles. Read more about this amazing DXpedition on their webpage: http://www.bouvetdx.org/ The DXpedition will showcase the new 4O3A Signature Power Genius 1.5 KW VHF Amplifier. This amplifier will enable the EME team to deliver full legal limit output into a 2 meter EME antenna array. So does this amp have 2m as an option? Or is this a special edition just for the DXpedition?
Quite interesting note Ria, thank you for update, may be special editiam with F6700?
is anybody know about that ?0 -
Hitching a ride, I'm curious too
Thanks Ria0 -
The expert 1.3k goes to 4m,it would be a matter of filtration to get to 2m. So it might be doable with slight modification.0
The devices used in the HF-6 version are specified to 500 MHz, so I'm guessing that the "Power Genius 1.5 KW VHF Amplifier" is a re-configured 2-meter-only lash up that might be able to include 222 MHz, but probably 2-meters only. Would be pretty easy to do by only changing the RF networks to the typical VHF coax transformers and leaving out all the different lowpass filter banks required for HF use. Here's a look at different examples for different frequencies: http://www.nxp.com/products/rf/rf-power-transistors/rf-broadcast-and-ism/1-600-mhz-broadcast-and-ism...0
I want to build a LDMOS amp that is driven direct by the 6700. It's not hard. Just one or two pallets, combiner, a small driver stage and filters, switching and protection circuits. And of course a PS.0
I wonder if they will be able to produce full legal 2M output hooked direct to the Flex 6700 XTVR port with it low level RF output or if they will use a intermediate amp like the DEMI 2MLDPA.0
Reading the EME page for the DXpedition it appears DEMI is supplying two 2MLDPA's to the team so that answers my question.0
Ria, have a look st W6PQL who has kits for 1KW amps. They are very easy to assemble0
That's exactly where I did most of my research.
Hi Ria if it may help
W6PQL RF-DECK and low pass filter
i use this board whit 5db attenuator at input for drive the BLF188xr
http://www.minikits.com.au/electronic-kits/rf-amplifiers/rf-high-power/2m-8W-Amplifier
and finally a home made Arduino DUE based controller and protection board
whit Ethernet for link to radio (soft ALC etc etc ...) ,display is a 4D system intelligent display
on 120V outlet i put 650W ,1250w whit 240V
IMD was not the best but meed the regulation ,primary cause by hight gain and from the pre-driver board
i have same for HF ;-)
73! Marc L. VE2OLM
That is a separate model. Ranko has been talking about this for some time.. You can also look into Larcan commercial TV amps that have been pulled from service.
I remember seeing this. Very good. Yes this is a hobby project for me.0
- 636 The Flea Market
- 144 SmartSDR+
- 261 SmartSDR CAT
- 199 DAX
- 45 Aurora
- 957 Maestro
- 57 FlexControl
- 931 Genius Products
- 302 Shack Infrastructure
- 141 Amateur Radio Interests
