My CAT lost its COM Port
Andrew Rose
Andrew Rose Member ✭✭
edited January 2020 in FLEX-6000 Signature Series
My usual operating configuration of the Flex-6500 is via Maestro.  For digital modes I have a Lenovo Laptop which runs Slice A to either fldigi or WSJT-X using CAT and DAX.
A couple of days ago both fldigi and WSJT-X failed to work correctly.  The displayed operating frequency didn’t follow the radio and Tx didn’t activate the radio.
I replaced the laptop with another configured the same this worked perfectly.  I noted that COM4 was being used.  I replaced the original laptop and noted that COM5 was displayed on the CAT window.  I attempted to change this to COM4 but failed.  Further investigation under:- Device Manager  /  Ports (COM&LPT)  / FlexRadio Virtual Serial Port (COM4) /  General  / Resources displayed the following message  “This device isn’t using any resources because it has a problem.”
I re-installed “SmartSDR v1.10.16” hoping that this would also re-install the CAT and DAX and solve the problem, but it didn’t.  I vaguely remember from the past that there was a prescribed method for working in this area, but I cant find it.  I don’t want to foul things up by deleting files etc.  I had a similar problem about four months ago which was solved only by purchasing a new laptop, I don’t want to go through that expensive exercise again!
  • Gonzalo
    Gonzalo Member ✭✭
    edited April 2017
    I've had a relatively similar situation since upgrading to 1.10.16. The problem seems to be CAT control. I have to restart it, sometimes a few times, for it to work properly.
  • Bob Brown - N8OB
    edited May 2019
    Any chance you are running Win 10, which was just updated?  I had a similar problem, removed my SSDR v1.10.16 and  then reloaded it.  I found out my VSP was missing some settings.  After installing VSP, my FLdigi and WSJT-x worked correctly again.
    Bob - N8OB
  • dlwarnberg
    dlwarnberg Member ✭✭
    edited May 2019
    Reinstall SmartSDR CAT it should fix the issue...  https://helpdesk.flexradio.com/hc/en-us/articles/205665325-How-to-Repair-the-FlexVSP-Virtual-Serial-...
    Keep in mind EACH computer could have different setups... i.e Laptop A uses CAT 5 for FLDIGI.... Computer B uses CAT 4 for FLDIGI.. not all will be the same.  But if you "loose" connectivity in the future try the above.
    Good Luck
  • Andrew Rose
    edited April 2017
    Didn't help!
  • Andrew Rose
    edited April 2017
    Re-installed SmartSDR two times and the problem has got worse!
  • dlwarnberg
    edited April 2017
    Can you provide a screen shot of your SmartSDR CAT screen?
  • Andrew Rose
    edited May 2019
    The problem is now in FlexVSP and CAT has stoped working!  I think its time to call the help desk.
  • dlwarnberg
    edited April 2017
    Have you followed the link I provided above?
