Computer can't see my 6300
Russ
Well suddenly my tower computer can't see my 6300 after about a year of no problems. It runs Windows 7. So I switched cat5 jumper from the radio to the computer and still the problem is there. Then I tried my MacBook Pro which uses boot camp and Windows 10 which I've used mobile and at the home QTH many times and it works great. At first I thought my tower was bad but it works with and without the internet for all other operations so is it a settings issue? Any ideas would sure help because after being spoiled by my big screens I think the laptop screen is just too small. Hi I might add that things started to go downhill a few weeks after installing the latest version of Smart SDR 1.1016 so I tried an older version and then went back to the 1.1016 and no joy. Help, Mr. Wizard.... Thanks Russ K5ZZR
Is the Flex the only thing on that Ethernet port in the computer?
What are the ip addresses of the computers and Flex? Make sure Windows firewall is off. Mike va3mw1
Yes Jim the cat5 runs right from the 6300 to the tower and I only have one Ethermet Port. Tnx
Can you ping the radio from the computer? The firewall may still be an issue. Mike0
Thanks Michael, the Windows firewall was off but the Avast firewall was ON. Works great now and thank you so much. Only thing is I'm nervous now the firewall is off. What can I do?
Check your Avast network settings. Mine changed after an auto Avast update. It set my Ethernet to public and that prevented my computer from seeing the radio until I changed it back to private
Same here Pat and thanks. I'll be watching that closely from now on.
- 391 Community Topics
- 664 The Flea Market
- 441 SmartSDR for Mac
- 206 DAX
- 60 Aurora
- 298 FLEX-8000 Signature Series
- 974 Maestro
- 948 Genius Products
- 348 Tuner Genius XL
- 127 Antenna Genius
- 308 Shack Infrastructure
- 216 Networking
