FreeDV tutorial
ON5AM
ON5AM Member ✭✭
edited January 2020 in FLEX-6000 Signature Series
I installed the FreeDV waveform. I have the Slide A with FDV mode. But when I transmit, I have some noise but not my voice. I suppose, the audio setup is wrong.
Can you help me ?Can you give me screenshots?
  • DaveC
    DaveC Member ✭✭
    edited May 2018
    Make sure you have DAX turned off and MIC set for your audio input
  • ON5AM
    ON5AM Member ✭✭
    edited May 2018
    Thank for reply.
    One question : does  the microphone put  in the Pc or in the flex ?
  • DaveC
    DaveC Member ✭✭
    edited April 2017
    Flex mic
  • ON5AM
    ON5AM Member ✭✭
    edited January 2020
    Is it correct ?imageimage
  • DaveC
    DaveC Member ✭✭
    edited April 2017
    You do NOT need to run the PC software. freeDV is built into the waveform. It does all the encoding and decode of freeDV.
  • ON5AM
    ON5AM Member ✭✭
    edited April 2017
    Ah ok, I tried without the Pc software with simply FDV option.
    But there are nobody who try this mode at this moment . I waiting for.
  • hans weijers
    hans weijers Member
    edited March 2018
    Try 3625 Khz on monday, wednesday and friday 16:45 local time and on sunday at 11:00 hrs local tiime. All in LSB, NOT USB !!! That's where the Flex comes into trouble: your Flex goes to USB on 160m, 80m and 40m. That's WRONG. Freedv is NOT a digital mode. It is LSB or USB, depending on the band you are using,  with digitized audio fed to the microphone input.
    73, Hans PA0HWB
  • Bill English
    Bill English Member
    edited March 2018
    What is the fix for the rig in USB? I can switch to LSB on 3.625, but when I switch to Free DV to automatically goes back to USB. What am I missing here?
  • hans weijers
    hans weijers Member
    edited March 2018
    From the Flexradio waveform there no fix to work on 160m, 80m and 40m because there LSB has to be used instead of the preprogrammed USB in the FDV waveform.
    That's why we in The Netherlands are using the program FREEDV.EXE as can be downloaded on freedv.org. Best 73, Hans PA0HWB
  • Bill English
    Bill English Member
    edited March 2018
    I will try it Hans, thanks and vy 73!
    Bill
