CW Skimmer SDR Bridge Problem
W9WLX_Chuck
I have a 6500 at 1.10.8 beta running CW Skimmer 1.8.3.350 with SDR Bridge 1.5.1 on Windows 10. I seem to have everything working, but there is an issue with the waterfall frequency on CW Skimmer.
All frequencies sync and follow--the slice receiver, SDR Bridge and the TX frequency on CW Skimmer. If I set the TX frequency on skimmer to the center frequency of the DAX IQ stream, it works as expected. However, if I change the slice frequency, off the center stream frequency, it shifts in the opposite direction. For example, if my center stream frequency is 7.020 and I double click on a station at 7.022 on the Skimmer waterfall, the slice receiver will follow and go to 7.022, however the station is really at 7.018.
I tried changing the CW sideband on the Phone/CW tab in Radio Setup, but it made no difference. Any ideas what I may have set incorrectly?
Chuck-W9WLX
Chuck-W9WLX
I've resolved the problem. In the CW Skimmer application, I had to swap the I/Q channels. Once I made the change, the waterfall on CW Simmer was in sync with the Flex's panadapter.
Hi Chuck,
Is this the setting you changed in the snapshot below? The Arrow points to the correct setting and I assume you had the Q/I selection set. Is that correct? If so I'll add the symptom and fix to the next version of the troubleshooting notes. They are available on the SDR-Bridge site and my web page:
http://www.nn4zz.com/Data/NN4ZZ%20CwSkimmer%20Bridge%20setup%2018-Feb-2016.pdf
Regards, Al / NN4ZZ
al (at) nn4zz (dot) com
SSDR / DAX / CAT/ 6700 - V 1.10.16
Win10
Yes, this is the setting. The default when I installed CW Skimmer was Q/I and it needs to be I/Q. I had not found the support document when I was initially configuring and I was using the trial and error method!
Chuck,
Thanks, I updated my setup and troubleshooing guide with your notes and the solution. The new version is dated 25-Mar-2017 and posted to my web page. See page 25.
http://www.nn4zz.com/FLEX6700.htm in the QuickLinks section or directly at:
http://www.nn4zz.com/Data/NN4ZZ%20CwSkimmer%20Bridge%20setup%2025-Mar-2107.pdf
I also sent a copy to Ed (SDR-Bridge author) to update his SDR-Bridge web page when he gets a chance.
Regards, Al / NN4ZZ
Win100
- 244 Community Topics
- 481 The Flea Market
- 7.1K Software
- 331 SmartSDR for Mac
- 243 SmartSDR for iOS
- 222 SmartSDR CAT
- 162 DAX
- 348 SmartSDR API
- 8.5K Radios and Accessories
- 746 Maestro
- 41 FlexControl
- 722 Genius Products
- 250 Tuner Genius XL
- 84 Antenna Genius
- 225 Shack Infrastructure
- 150 Networking
- 120 Contesting
- 114 Amateur Radio Interests
- 805 Third-Party Software
