Radiosport RS60CF headset with M350-ADJ mic, audio output too low on Flex6500
Did you try adjusting the M350-ADJ setscrew on the mic? it's got adjustable gain. it may be set too low?
Cal/N3CAL0 -
Is the Bias+ turned on in configuration?0
Cal & Ken
Thank you but the Bias is Enabled & I found that the adjustable gain was already pre-set on Max. I guess I'll have to speak louder!
73 Ray G3XLG
Did you contact radiosport tech support? I don't speak loudly yet I can peg the meter easily. You may have a defective one or they may be able to walk you through.0
I have the same headset and I can easily peg the meter. I'm using the Foster connector up front for my headset and the XLR on back for my PR40. Call Dave and have him walk you through it.0
Rory,
I also have the PR40 plugged into the XLR jack on the back of my 6700. I have the BIAS +20 preamp selected and have to run the mike gain at 100%. How high do you have to run the mike gain on the Flex for your PR40?
Is it possible that your cable is defective and not allowing full audio transfer?
If you hadn't said you used this same headset/mike on another rig, I would have thought that perhaps you weren't speaking closely enough to the noise cancelling mic element, which reduces drive very quickly.
So that has me leaning towards a defective cable, or perhaps a defective mic element.
I agree with Ria, Call RadioSport Tech Support....1 -
I am using a PR781 mic plugged into the XLR jack and am using the same settings as Norm.0
The cable was supplied new two months ago.
I have taken advice & emailed RadioSport concerning the problem - Not so easy to just call them from the UK!
I will update this thread when I hear something
Ray G3XLG
Hello Norm, sorry I don't remember and I have my shack tore apart right now, I might be able to let you know tomorrow night or on Sunday.0
Problem Solved by Dave at Radiosport, thank you!
I feel such an idiot ....! Whilst I had enabled the Bias in the "Settings/Phone CW Tab", I had not clicked on the separate 20db boost button. When I did this there was plenty of audio gain!
For info I show below Dave's advice:-
"We have recently dropped the -ADJ nomenclature for the M350 Mic (part numbers getting way too long when appended to headsets) and yes all M350 do have adjustable gain, although virtually everyone runs them at full gain. Be certain that the +20dB Boost (next to the BIAS) is enabled (highlighted Blue just like the BIAS) as I've seen this disabled if the Mic Profile has been saved without it enabled and so each time the radio is started it goes back to the profile setting. If you have verified this then there is something wrong.
Please note we have only had one M350 failure in 7 years and that Mic was blown from a static discharge (handling the headset in very dry conditions without discharging one's self before picking up the headset). That type of failure is complete, the Mic won't work at all. If yours works but has low output, please have xxxxxxxxxr at xxxx check it out in their workshop. They will be happy to replace if it is defective."
Gee I wonder who's mic element he's talking about with the dry environment? Must of been one those DXpedition guys out in the desert!!
Anyhow glad was Dave was able to get you up and running, the RS60CF was one of my best investments so far!1
- 246 Community Topics
- 488 The Flea Market
- 7.3K Software
- 328 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 343 SmartSDR API
- 8.5K Radios and Accessories
- 768 Maestro
- 42 FlexControl
- 726 Genius Products
- 251 Tuner Genius XL
- 84 Antenna Genius
- 223 Shack Infrastructure
- 150 Networking
- 118 Contesting
- 116 Amateur Radio Interests
- 810 Third-Party Software
