My Maestro Is Beeping
L.Kubis
Run!
D0 you have a battery installed? May need charging.
Somehow my message didn't get through the first time around.
My Maestro started to beep at me a couple of days ago at irregular times. Usually it is a single beep followed after some time with 2 or 3 beeps. Obviously this is a code for something and I'm not sure for what.
I have my Maestro on AC power all the time using the supplied power pac. I do not have an operating battery installed at this time.
Is this a warning for something about to fail?
How can I stop this annoying alarm?
Cheers!
Lloyd
VE3ERQ0 -
No problem, Lloyd, I understand. I'll take off my comment above if you find it annoying.
No problem with the comment, Richard -- the beeping hasn't reached the continuous state yet.0
I was concerned that the dilithium crystals in your warp drive were melting down. I'm glad to hear that the situation has stabilized :-)
Emulating the road runner?
Dive! Dive!0
I would recommend notifying Flex. Occasional beep from a Windows OS machine can possibly indicate a problem with a driver, hardware or address conflict. Since the Maestro is running Windows, the folks at flex may be able to look at the event logs and get an idea of what is going on.0
I have converted this topic to a support HelpDesk ticket (http://helpdesk.flexradio.com) for expedited issue resolution. Please respond using the HelpDesk ticket for issue resolution.
If anyone else is experiencing an issue similar to this one, please submit a HelpDesk support ticket for issue resolution.
- 634 The Flea Market
- 132 SmartSDR+
- 198 DAX
- 42 Aurora
- 956 Maestro
- 298 Shack Infrastructure
- 210 Networking
