2 Raspberry Softether Setup help needed
Hello,
I have 2 raspberry Pi3s with SoftEther installed. With the help of the fantastic k6ozy (Chris) videos I have successfully connected to my Home Pi via my remote Laptop. I am now trying to VPN in with my Maestro with my second Pi3. I am also using k6ozy videos for this. The remote path goes through my iPhone. The Pi3 connects to the hotspot fine. On the Maestro I see I am connected with a yellow triangle/explanation point meaning it doesn't see the internet. Of course the "radio" page of the Maestro is blank.
I could use some help in sorting through this. I am out of ideas.
TIA,
Jim
ka7gzr
Hi Jim,
The most important thing is that you must (must must must) have a bridge setup in the softether config on the pi you are connecting to the maestro. Otherwise your softether connection has nowhere to go. That bridge will bridge the RJ45 LAN connector to the SoftEther connection.
It is at 12:18 in Chris's video:
https://www.youtube.com/watch?v=HaH8LJ6_MQc&t=1046s
Make sure you select eth0, since he clearly says wlan0 was a mistake.
Ria0 -
Hello Rea,
Yes I am aware of Chris's error in specifying "wlan" instead of "eth0". He has a note that pops saying "don't listen to me- it should be eth0". I laugh each time I see it. I have been through his video so many times I have it about memorized.
One very good thing is that I know a whole lot more about Linux than I knew before!
I do understand that a bridge needs to be set up- I believe where the issue is the connection between the Remote Pi and the Home pi is not being realized.
Jim
Sorry, lost internet here (very unreliable).
There are a few elements for this to work properly:
1. The server side pi (radio side) must be setup to allow LAN to LAN connections, I assume you did that.
2. Port forwarding on your router must be setup correctly - 500, 4500, 5555. I believe 5555 is a TCP port and the rest are UDP (off the top of my head).
3. The client (maestro) end must have wifi connectivity. You can use the method Chris describes or something else I found a lot more elegant:
https://planb.nicecupoftea.org/2016/03/20/wifi-connect-quick-wifi-access-point-to-tell-a-raspberry-p...
(I recently did a pi for someone with this plus a status indicator and reset button using the GPIO btw, pretty slick, they can see the connection status and even "forget" known wifi on demand).
4. The maestro end must have a cascade connection setup to your server end (radio end) pi.
5. There must be a bridge on the maestro end pi.
Without seeing details of your configuration, it's hard to guess but I'd run through these to see. I think in most cases it's either the bridge part or the firewall port forwarding that trips people up.
You can use the GUI to check the status of the cascade connection. As Chris advised in his video, you should put an IP on the wired ethernet interface for admin purposes and you can use that to connect to the Pi to check connection status.
If you're still stuck, post some screen shots of your config.
Ria
One other item I don't understand is my wlan address of my router is never specified. I have port forwarded the ports of my home raspberry. However, on the remote raspberry Pi I never specify the wlan address of my router. Maybe that's the issue. Did I not miss-interrupt Chris's directions?
Jim
Usually what you do is set up dynamic DNS on the home pi (whereby you get a hostname like ka7gzr.softether.net and that is tied to your home internet's external IP) and then the remote pi connects to that. When setting up the cascade connection on the remote pi you'll connect to the dynamic DNS hostname. Hope that made sense.
Ria0 -
Yes I understand that. On the Maestro Pi I specify on the "cascade" host entry as "ka7gzr.softether.net" Where is that specified on the Home Pi?0
In the "dynamic DNS" section.0
Another thing you can try is to connect from a Windows 10 laptop using the built-in VPN bridge to your home Pi and make sure the Pi server is working OK. Then continue to troubleshoot your remote Pi. 73 Bill VA3QB0
Thanks Bill,
Yes I can "successfully" connect with my Laptop remotely. Although the connections often drop and are mostly unreliable- but that's a different subject...
Jim
Thanks Ria.
I did check and everything in the "dynamic DNS" section is how it should be. I assigned a name to the "****.softether.net" on the Home side. I have established a bridge on the Maestro side- at least I think I have.
I will send you config files if you like. Any specific ones?
Also I can send you the two config files for my home and remote txt files.
Earlier Chris (k6ozy) was able to get into my Pi3s and look at them remotely but he has not been around for awhile.
Jim
ka7gzr
Problem Solved!
I found my last fatal error which was not including 3 alphas in my DNS Hostname.
Thanks for all the help especially Ria (N2RJ) and Chris (k6ozy).
Jim
ka7gzr
- 244 Community Topics
- 481 The Flea Market
- 7.1K Software
- 331 SmartSDR for Mac
- 243 SmartSDR for iOS
- 222 SmartSDR CAT
- 162 DAX
- 348 SmartSDR API
- 8.5K Radios and Accessories
- 745 Maestro
- 41 FlexControl
- 722 Genius Products
- 250 Tuner Genius XL
- 84 Antenna Genius
- 225 Shack Infrastructure
- 150 Networking
- 120 Contesting
- 114 Amateur Radio Interests
- 805 Third-Party Software
