Integrate Flex-6500 with fldigi on iMac
Is anyone out there up to date on this particular interface and can help?
Easier, and more pleasant than you may expect. Are you using DogParkSDR as your Flex client? There is a tutorial on the dogpark site. You will need a DAX replacement, like Loopback or Sound Siphon, to move audio to and from the rig and applications. Transmitter keying via VOX is probably best using FLDIGI. Good luck and enjoy!0
Yup, easy to put together as George mentioned, but it does require several pieces.
dogparkSDR
MacLoggerDX (optional, but does make PTT easier)
Loopback or Sound Siphon (I prefer loopback, but YMMV)
Fldigi
Once Loopback/Sound Siphon is installed, dpSDR & Fldigi can feed/receive audio via that virtual audio cable. VOX is the best way for that.
If you use MLDX, it can connect to the Flex as well and you can use that for PTT through the use of an AppleScript program to take the PTT request/release from Fldigi and trigger that using MLDX.
There are scripts to take your logs from Fldigi and feed it into MLDX; either on demand or automatically after every QSO is saved.
My setup is dpSDR and MLDX running, with Fldigi triggering a modified script (from DJ7AQ...modified to check and reload every 0.1 seconds rather than every 1 second for more responsive PTT) for PTT. Logs are auto logged from Fldigi to MLDX using the AutoLog script running all of the time on my Mac.
The extras folder in the MacLoggerDX download has all kinds of scripts and instructions included.
As George said, "easy and more pleasant".
Many thanks for this most useful information.
It looks as if the only way to interface fldigi on an iMac is via ‘dogprkSDR’’. This is a shame as I really wanted to be able to use the ‘Maestro’ which I prefer to ‘dogparkSDR’, never mind.
Thanks again as ever for your help.
Andrew G4AUE
- 333 Community Topics
- 601 The Flea Market
- 7.9K Software
- 6.2K SmartSDR for Windows
- 399 SmartSDR for Mac
- 263 SmartSDR for iOS
- 247 SmartSDR CAT
- 184 DAX
- 371 SmartSDR API
- 9.1K Radios and Accessories
- 17 Aurora
- 169 FLEX-8000 Signature Series
- 912 Maestro
- 52 FlexControl
- 880 Genius Products
- 318 Tuner Genius XL
- 116 Antenna Genius
- 279 Shack Infrastructure
- 196 Networking
- 137 Contesting
- 730 Peripherals & Station Integration
- 137 Amateur Radio Interests
- 949 Third-Party Software
