CW slows down
Giulio
Giulio Member
edited June 2018 in SmartSDR for Windows
Dear All,
During this last ARRL I experienced that, randomly, cqing, CW slows down, or takes come seconds of pause between letters. It is a problem recognised also by other OMs. I use the virtual WK interface.
Best 73s!
Giulio IZ3EAW
  • Duane_AC5AA
    Duane_AC5AA Member ✭✭✭
    edited June 2018
    Are you running one of the recent Beta levels of software?
  • Giulio
    Giulio Member
    edited February 2017
    Yes I do
  • Tim - W4TME
    edited March 2017
    Using the WinKeyer emulation, the data is processed through the CAT application that is running locally on the PC.  If there are things slowing down the PC (DPC latency, excessive use of the swap file, network latency, etc..) these factors will affect the timing.
    Letting us know what action you take to possibly correct the situation would be helpful.
