Flex5000a will not start the "Use" button does not light
Robert Fraley
I have been using the flex for a couple of years but now it does not start. The radio does not light the USE light on the interface and will not start. I dont know where to start troubleshooting.
Is the Power light on on the radio?
Is the firewire cable plugged in on both ends?
Look in Device manager and see if the firewire is there and is active and has no errors.
bring up the Flex Firewire Driver program and see if your radio shows up there , if not in the computer make sure the firewire card is fully seated, if in dought pull it out and re-set it.
If it doesn't work after that then REPLACE the firewire card and firewire cable to see if that helps.
73's
Bret
WX7Y
I have just uninstalled my interface. I thought I had all the files saved to re-install it. Can you give me a hand with the files to re-install the software. I thought maybe it might have some problems. Thanks Robert
just download PowerSDR at http://www.flexradio.com/downloads/powersdr_v2-7-2_installer-exe/
View it in the Download Directory then Right click on the file after you have it downloaded and I ALWAYS use "Run as Administrator" to install programs that have drivers and say YES to everything.
Be sure to Re-Boot after the install
73's
Bret
WX7Y
Thank you, I have it loaded but its not showing in the available radio interfaces. How do i start it now?
Your radio is no longer communications with the PC. This is your issue. Reloading software will probably not solve the issue. This can be a Windows operating system issue related to the system 1394a bus driver or a physical issue, like a bad FireWire cable or a malfunctioning FireWire card. I'd open a HelpDesk support ticket0
Thanks Tim but I have already uninstalled the interface. How do i get it back to the available radio interfaces. I see only the demo now?
When the radio is properly communicating with the PC, it will automatically show up in the chooser.0
even though I deleted it?
I think you are missing a very fundamental issue here. If the radio hardware and the PC are not communicating via the Firewire link, the radio will never show up in the chooser. There can be a multitude of reasons why this might be happening.
As I recommended before, I strongly urge you to open a HelpDesk support ticket. The Community is not a place where FlexRadio provides one-on-one support.0 -
ok, thank you. How do get helpdesk support?
Thank you much Tim. Sorry for the trouble.
No problem.0
- 375 Community Topics
- 104 SmartSDR+
- 425 SmartSDR for Mac
- 999 Third-Party Software
