No graphics acceleration, where does SmartSDR get info?
Dave - WB5NHL
I using an AMD quad-core processor (A10-6800K) accelerated processor on an ASUS F2A85-V Pro motherboard. The graphics processor is an integrated Radeon HD 8670D. SmartSDR settings says No graphics acceleration??? Where does SmartSDR get this info? BTW, this hardware drives 3 monitors out-of-the-box using an added display port -> DVI adapter for the 3rd monitor.
Dave, SmartSDR is a WPF application and when it starts it queries the graphics subsystem for it's capabilities and uses what it is told it has. Obviously the embedded graphics adapter has the capability to do the necessary graphics rendering, but something else is preventing it from properly informing SmartSDR. Make sure that your video drivers are up to date. That is where I would start first. Then make sure you have all of your .NET components updated too.0
Everything is up to date on both Windows side and AMD drivers side. Some Googling has NOT been helpful. AMD just keeps saying it supports DirectX 11 (I'm running) etc etc. I also dug into the BIOS turning on "extreme" for the GPU setting - no change. The video is performing ok; it just surprised me that there was no h/w acceleration. The only thing I can think of now is the fact I'm using an extended desktop across the 3 monitors? But, then serious gamers are using this kind of configuration. Go figure.... Thanks. I'll repost if I find an answer.0
You can set a registry setting to disable or enable acceleration in WPF. This link provides you with the information to check. May be worth a look. http://msdn.microsoft.com/en-us/library/aa970912.aspx and this link within that page will explain the rendering levels. It also contains info on the DXDIAG tool. http://msdn.microsoft.com/en-us/library/ms742196.aspx1
Some more Googling kinda revealed the issue. It seems to be a driver issue with AMD. Since I am using the custom AMD driver the normal Windows ability to turn on/off/adjust acceleration isn't available. Going into the AMD Vision Engine Control Center reveals alots of tweaks but no hardware acceleration setting. Given everything seems to work well, I guess I'm at the end of the quest.0
i have the same motherboard and processor. How did you Plug the monitors? One to dvi port, one to display port with adapter, and the third one? Vga or hdmi ? Are the three at the same resolution? Or may I use one that is bigger?0
- 337 Community Topics
- 578 The Flea Market
- 7.7K Software
- 6.2K SmartSDR for Windows
- 386 SmartSDR for Mac
- 253 SmartSDR for iOS
- 244 SmartSDR CAT
- 177 DAX
- 365 SmartSDR API
- 9K Radios and Accessories
- 126 FLEX-8000 Signature Series
- 891 Maestro
- 50 FlexControl
- 849 Genius Products
- 298 Tuner Genius XL
- 113 Antenna Genius
- 269 Shack Infrastructure
- 190 Networking
- 134 Contesting
- 701 Peripherals & Station Integration
- 131 Amateur Radio Interests
- 924 Third-Party Software
