FLDIGI keys the transmitter but no sidetone
David Brown
David Brown Member ✭✭
I know this has been covered in past posts, but I still do not understand.  I am trying to get FLDIGI to work on my Flex 6500.  Using CWX it keys the transmitter with a sidetone , but using FLDIGI macros, it keys the transmitter but no sidetone. What am I doing wrong?
  • Tim - W4TME
    edited March 2017
    Do you have MON (monitor) enabled in SmartSDR for Windows?  If not and everything else is working, I suspect that is your issue.
  • Andrew O'Brien
    Andrew O'Brien Member ✭✭✭
    edited February 2017
    Fldigi usually expects you to be in USB or DigU when doing CW since it is not true CW.
    Andy K3UK
  • David Brown
    Thanks that is what it was looking like,  with DIGU I can not use my bencher key?
    Dave
    W7FYW
