Anyone Using AT-AUTO with Flex 6000 USB?
I used my HF-Auto between the amplifier and antenna. Set the tune output on the Flex to 1 watt and the Palstar tuned automatically with no issues. The amplifier sent the amp about 12 watts at this setting. I did not use any other cables.
I have an AT-Auto, not the same as the HF-Auto, but I use a CIV cable because I have an ICOM radio also and control my amp and coax switch using CIV as well. DDUtil enables it all and Steve even added a macro that enables the "tune and save to memory" function equivalent to pressing the front panel Tune knob. In DDUtil you use the Passive Listener section of the Port tab and define a "**** Radio". If you want to go this route email via address in qrz.com and I'll provide additional details. The AT-Auto does have frequency decoding to operate as described in the prior post (Vintage radio settings) but then you're not taking full advantage of it's memory to automatically tune without transmitting. **** KF5SA
Just looked at your Web site and you have an HF-Auto not an AT-Auto so I don't know if my approach applies or not - don't know how much Palstar had to change when Don left with the AT-Auto design rights.0 -
Sometimes when I get tired of hearing my 6700's automatic antenna tuner relays beating themselves into submission so I put my Flex in Bypass and use my HF-Auto. If you're not concerned about tuner memories there's no need for any control cables. The Palstar HF-Auto automatically senses the frequency and does its thing.
Thanks to all who have taken the time to reply thus far. I think I should clarify. I'm wondering if I connect the approved FTDI USB to Serial cable from the Flex to the AT-AUTO RS232 port will the tuner follow frequency changes from the radio. (like my 1K-FA does)
I'd like to have the AT-AUTO follow frequency changes via FLEX CAT without the need to TX. Anyone out there using the AT-AUTO (not HF-AUTO) in this fashion?
Ahh! the HF-AUTO in my shack photo, I see how that could be confusing! The AT-AUTO may be used in another station set-up and I was hoping to get some feedback before I purchased it.
Thanks for all your feedback!0 -
I have tested the AT-Auto with USB to serial cable plugged into the radio. It does work fine. I was using Kessler Engineering's 2.14 firmware but should work with the PalStar firmware also.
In PalStar setup make sure to set radio type to Kenwood CAT only, no Ext Tuner I/O. Document baud rate and make sure you select 8,n,1.
In the radio USB setting menu set cable type to CAT and set baud rate.
The advantage of connecting CAT to the tuner is the tuner can pre-tune before applying RF. I had modified my AT-Auto to remove the balun and install a second coax connector. I programmed the tuner to automatically switch antennas when switching bands and also automatically bypass the tuner on bands where the antenna was resonant.
Thanks Dave, This is exactly what I was hoping to find out. One question. Did you plug the USB/FTDI cable 9 pin end directly into the AT-AUTO RS-232 port, or did you have to build the cable shown in the manual (for Kenwood radios) to put in between? Thanks again for taking the time to reply!0
I used a straight thru DB-9 m/f extension cable from the adapter to the RS-232 on tuner. I had used the same cable previously to the PC com port with DDUtil.
73 Dave wo2x
I bought the kenwood cable from Ameritron and plugged it directly into the ALS-1306. connected the other end to a Nul-modem USB cable. Plug the USB into the Flex. You will also need an RCA cable from the Flex to the ALS grounding relay. There are three of them to choose from on the flex. Connect it to the relay port on the ALS-1306. This will allow the Flex to key the amplifier.
- 246 Community Topics
- 488 The Flea Market
- 7.3K Software
- 328 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 343 SmartSDR API
- 8.5K Radios and Accessories
- 768 Maestro
- 42 FlexControl
- 726 Genius Products
- 251 Tuner Genius XL
- 84 Antenna Genius
- 222 Shack Infrastructure
- 149 Networking
- 369 Remote Operation (SmartLink)
- 118 Contesting
- 116 Amateur Radio Interests
- 810 Third-Party Software
