Winkey Emulation SSDR v. 1.10.15 stutters with N1MM+
Mike_N1MD
Worked CQ 160 contest last night with Flex-6700 and N1MM+ using Winkey emulation. I had lots of problems with function keys not responding to mouse presses and macros that send one letter then pause and then complete the macro.
I thought this had been solved since I did not have problems in contests with the previous beta release or the release before that. Alas, that is not the case.
I am back to my trusty, high reliability hardware Winkeyer -- and I will not even attempt using the SSDR emulation in the future until it is proven that it works. It is not worth the intolerable disruption during contests to try to use the emulation.
Mike N1MD
Mike N1MD
4
It's not just N1MM. It happens with CWX too. My F1 key is programmed to send my call, and it frequently comes out with an additional space between W and 0, or elsewhere in the sequence.
Rick, W0FG1 -
I am having the same problem with this release. CWX also stutters at 22 WPM or up, at least. I like to run CW at 28 to 35 WPM.
Keith
W7ZAC
I reported a problem with N1MM+ sending using winkey. I hadn't realized the winkey emulator actually used CWX. Since then, I tried using CWX directly and notice the problem is there. When I send my call sign (or any word), there's often a space between the first and second letter. Enough of a space that K 4VD or K EVIN often gets a response from the other side before the 4VD or EVIN is sent.
I am told this issue is covered by defect 4416.
I have wondered why Flex included a CW keyer but ignored other digital modes. Even if this issue did not exist you have to admit CWX is a pretty minimalist CW sending program. Adding the winkey emulator on top seems to add the missing capabilities but then I ask again, if you have winkey, why have CWX? But I'm getting off track.
I'm thinking of purchasing a standalone winkey keyer. I've never bought one before. Can someone make a recommendation of a good make/model? Are there any considerations between models or is one winkey emulator the same as any other?
Kev K4VD
I have heard of that issue but it seems pretty sporadic. Before the fixes were applied, I was having much of the same issue as you. CQWW CW I was tearing my hair out because all of a sudden the rig would **** a lot of high speed CW in the middle of a run or S/P, after stalling a few times before. However, since 1.10.15 beta that hasn't happened (I'm doing the CQ 160 contest right now).
There may have been multiple issues but I know for sure I am not having it anymore, and this is after the dev team published a fix (which became part of 1.10.15 beta).
Very strange.
I hope they get to the bottom of this.0 -
Ditto here - played for four hours in cq 160m cw today at run rates of up to 200q per hour and seemed ok here 73 Steve gw9j / gw0gei0
I was having the same issue and found it went away when turning off QSK in the CWX window.
Also I was running 5 ms delay in the CWX window with QSK enabled. I increased it to 15 ms and seemed to help. Haven't heard a misfire since.
Thanks Dave, I'll try that. I'm pretty sure I've always got QSK on here.
Kev
Steve... note Dave's post below. How was your QSK and delay set during the contest?
K
Ha! I think that did it. I set the delay to 15 and QSK off and sent a long string of CQs. They flowed nicely. Then I turned on QSK (leaving 15 for the delay) and I would get intermittent skips. In fact, something I never noticed before, the MOX button flashes off momentarily when there's a skip.
I am going to keep sending loops until I'm convinced but maybe the QSK and the MOX flash might give FRS some insight into the problem.
For those not having the problem, any chance you could test with QSK on and report results? I really use QSK a lot, especially during a contest or DX hunting.
I'm not sure this will help. There's no audio because FRS doesn't send sidetone over to the computer!!!!!!!But the video shows how MOX flashes off when sending CWX. Basically I hit F3 a bunch of times (sending CQ). The flashing MOX button coincides with elongated gaps between letters.
https://goo.gl/hxUSoe
Kev0 -
Tried it with QSK off, Delay set to 17, CWS at 37 and I'm still getting skips.0
I have entered this problem report (#4437) into our bug tracker for additional investigation. Thank you for the defect report.
- 338 Community Topics
- 580 The Flea Market
- 7.7K Software
- 6.2K SmartSDR for Windows
- 387 SmartSDR for Mac
- 253 SmartSDR for iOS
- 244 SmartSDR CAT
- 177 DAX
- 365 SmartSDR API
- 9K Radios and Accessories
- 891 Maestro
- 50 FlexControl
- 849 Genius Products
- 298 Tuner Genius XL
- 113 Antenna Genius
- 269 Shack Infrastructure
- 190 Networking
- 134 Contesting
- 702 Peripherals & Station Integration
- 131 Amateur Radio Interests
- 924 Third-Party Software
