1.10.8 crashes intermittently usually after flex control get intermittent.
Ed
1.10.8 crashes intermittently usually after flex control get intermittent. Have to restart software to get up again, sometime Flex knob still intermittent and must shut down radio and reboot radio and software. This is new with the Beta version. Anyone else have similar problem?
Ed...K1EDG
Ed...K1EDG
Hello Ed...I'm using the Beta version and so far the only issue I have is port duplication...Flex Control and platform both working solid...I realize this does not help you very much. I would recommend opening up a Support Ticket...Take care
Ronald
Yes, I know a number of people including myself having this issue...!!!
I've had the problem twice with 1.10.8 using a Maestro. Maestro lost connection with the 6500 and couldn't see it to reconnect until I power-cycled the 6500.0
If you are having the Com port "in use" issue, which can affect the operation of any com port device, such as the FlexControl, there is an article in the HelpDesk that describes how yo reset the port reservations (in use flag) on com ports that are not actually in use. https://helpdesk.flexradio.com/hc/en-us/articles/115000504463-Removing-In-Use-Com-Ports-for-Availabl...0
After several days or running V10.15.33 seems to cleared all problems.
Thanks for the replies
73 Ed K1EDG0
- 654 The Flea Market
- 384 SmartSDR API
- 51 Aurora
- 967 Maestro
- 938 Genius Products
