Flex 6000 SSB Audio Complaints
Listen to the Flex net. Most signals are good, but not that good compared to other transceivers. To the discerning ear, you generally can tell a Flex is in use by the slight echo on the signal due to RF ingress. On 6300's it can be quite the challenge to vanquish completely. A lot of money is spent on expensive microphones for communications where intelligent tweaks of EQ and isolation can many times afford greater benefit.
W7NGA dan
Seaside, Oregon1 -
Mark - sorry I am late to the game. I am doing double time work this week. I am converting your Community post to a HelpDesk ticket. I want you to update the ticket with the serial number of your radio so we can determine if what you are experiencing is noise on the mic ground.0
Mark, Mark, Mark. You'll never have great audio until you get your ticket punched by one of the audio "gatekeepers" on 75m, 40m, or 20m. Of course, to do that you will have to endure years of endless hours of on air-fiddling with external audio processors, equalizers, and studio microphones, all under the tutelage of a small group of "certified" audio experts. Unfortunately, you will never achieve full recognition as long as you are using a Flex radio, because THEY don't have Flex radios.
Remember the line from the Ricky Nelson song, Garden Party?
"But it's all right now, I learned my lesson well.
You see, you can't please everyone, so you got to please yourself"
3 -
As a retread person, I'm available most times, and all except 6 meters, and the 160 meter antenna is a real cloudwarmer from here. 80 40 20, depends on the time of day of course.0
@Kev K4VD - deep low voice here too - though if you meet me on the radio it doesn't sound like that!! <grin>
If you want, toss me a reminder email and I'll pop some screen shots of how my EQ is set up for you.
I recognized long ago that to be heard AND understood I needed some help. So I try to start with a very flat mic and use either external or on-board processing to modify what the other person hears.
I also do my own brew of modification of received audio to improve my comprehension of the other station and to compensate against my hearing frequency response. I've had visitors say the would adjust the RX audio differently, but they also noticed I ended up working stations that with the RX audio flat we couldn't begin to understand.
In the end what works for you is what is "good."
FRS suggestion to check for any grounding issues with a Help Ticket makes a lot of sense too.
Looking forward to hearing your next audio captures or hearing you on the air.
Steve K9ZW
Yeah that's pretty much how it is. So I tell them I'm running an old broadcast transmitter I saved from the scrap heap... lol1
- 378 Community Topics
- 116 SmartSDR+
- 37 Aurora
- 923 Genius Products
