Will this work for Auto Band changing for Ameritron ALS-1306 to A Flex 6300?
Richard Kemp
Hello, I want to be sure that I understand if this will work. I need to buy the cable to connect a Kenwood radio to the Ameritron ALS-1306. Then I also need to buy the Startech-ICUSB232FTN cable. Then to make it all work, 1- load the new Smart SDR into the radio, 2-connect the two cables together. 3- Connect the USB end of the cables to the Flex 6300 radio, Connect the Ameritron cable to the ALS-1306, and that is it. Will the amplifier follow the radio from band to band with this setup? Thanks for your help. Rick
Yes - My 6700 does it perfectly in all slices. I would expect the 6300 to do the same. I would buy the Kenwood cable from Ameritron. I did.
Email me your phone number at k4cae@att.net if you have any additional questions.
You don't need the Kenwood cable if you can put a DB-9 connector on the end of a cable!
You can do this two ways, one way is with FTDI DCB cable and second the FTDI Serial cable, works great either way you go WITH-OUT the Keywood cable.
Contact me direct " wx7y at arrl.net " if you want to build it yourself by installing the cable end connectors.
73's
Bret
WX7Y
Bret - I have the "serial-to-USB" cable I got from Flex for my 6500. The DB9 connector is MALE - as is the connector on my ALS-1306. It seems like I could get a "female-to-female" adapter and it would be the same as your explanation above. Am reading this right? Thanks in advance!1
I think you will need a Null Modem adapter instead of just a female-to-female adapter.
I have moved on since I ran the 1306 so it has been a while since I did the cable so not real fresh in my head.
73's
Bret0 -
Thanks Bret!1
Does it pandswitch to 12m and 17m bands? My 6300 will not with latest 2.x software.
Keith
W7ZAC0 -
I have a 6600, 1306, v2.4.9 and it is changing bands correctly. The 1306 uses the same band coils and relay for 17 & 15 and 12 & 10 meters. When I switch bands between 17 & 15 or 12 & 10 meters the band relay will not click - that is normal. The band number light changes as expected. Just checked 20 & 30 meters - it also uses one coil set and relay for those two bands.
I'm also using the Ameritron Kenwood cable along with a FTDI null modem cable and a db-9 gender changer.0 -
O my 6300, it will not switch to 12 or 17 meters. I have a support request filed with Tim.
No useful reply from him yet. Keith W7ZAC0 -
i have problem with flex6500 and ameritron 1306 .... the radio keys the amp, but no automatic band changing takes place, and the band switch is set on REM. i am using the ameritron db-usb6000 cable. if you had to make changes within sdr - please be specific with the changes. anybody using an alernate cable, or has any solutions, i can be emailed at buddys70@gmail.com thanks0
- 384 Community Topics
- 643 The Flea Market
- 148 SmartSDR+
- 436 SmartSDR for Mac
- 262 SmartSDR CAT
- 284 FLEX-8000 Signature Series
- 961 Maestro
- 936 Genius Products
- 343 Tuner Genius XL
- 799 Peripherals & Station Integration
- 142 Amateur Radio Interests
