Writelog for RTTY contesting
Hi all,
I used writelog in the ARRL RTTY RU contest last weekend and had a lot of problems. This was my first RTTY contest using the flex, I have previously used writelog for all my contest needs and like its operation and interface. I also rather like the fact it uses IP comms to the Flex rather than using DAX and SmartSDR Cat.
I used the following setup
Smart SDR v1.9.13.173
Flex 6500
Windows 10
Latest writelog version 12.12C Dec 2016
Writelog Flex driver - WlFlexDriver1203A (setup as single radio)
MMTTY as main RTTY interface using XMMT.ocx
Network uses a Gigabit switch between PC and Radio with cat 6 cables
The problems I had were
1 - For no reason comms would start to drop packets (upto 30%) Rebotting writelog sorted problem once. Other times the network issues persisted, tried rebotting everything many times including PC
2 - Keying of the radio stopped and I had to Revert to using SmartSDR Cat port in MMTTY setup to key rig.
3 - Intermittent operation of Focus helper
I also had the latest version of 2tone crash a few times in my clone receiver.
It was running with less network traffic than my normal general logging setup of DXlab and sdr bridge with a couple of CW skimmers running. I still tried slaving the switch and network cables but that had no effect.
I was running unassisted in RU but for BARTG and WPX RTTY contests I want to setup a RTTY skimmer to post to the bandmap. But need to sort out base logging/RTTY software first.
My questions are
1 - Has anybody got writelog rtty contesting setup running successfully using IP comms and writelog flex driver.
2 - Anybody else experience these issues.
3 - What RTTY contest setups do people run with the Flex 6000
I see my choices as
- sort out writelog and ip comms
- run writelog with comms using TS2000 rig option with smart Cat and DAX
- Use N1MM+ Smart Cat and DAX (N1MM unfortunately does not support IP comms and the smartSDR API)
There appears to be a lot of mention to N1MM in latest Beta release does Flex have a special relationship with N1MM devt team hence making it a good choice for the future.
Any help appreciated Andy M5ZAP
If you haven't already, you might want to copy Wayne (Writelog author) with this info.1
I shared this on the alpha list, we have a couple of WL users there. I think the N1MM stuff is simply because more hams use it than any other logger. but we do testing with all major loggers and even some lesser used ones.
Ok Duane thanks I will do. I couldn't find a writelog support group , I'm sure there used to be a yahoo group. I presume his contact details are on the writelog web page.0
Thanks0
Hi Andy, I am running the same, 6300, Writelog 12.xx, WlFlex Drive, MMTTY within Writelog.
I made abouut 500 RTTY Q's in the RTTY Roundup with no problem at all.
Here is my comments:
My questions are1 - Has anybody got writelog rtty contesting setup running successfully using IP comms and writelog flex driver.
Yes, but what do you mean by IP Comms?? I am using DAX and CAT only.2 - Anybody else experience these issues.
No.
I see my choices as
- sort out wr itelog and ip comms -- Use DAX and CAT
Select Flex 6300 series from the Rig pull down in the Setup menu in Writelog
N1MM is used by many people. I have not use it as I am a longtime Writelog user
I don't know what to tell you about your network problem. But I have no problem here with direct connect to my home network.
Please contact me if you have any questions.
Any help appreciated Andy M5ZAP"
Joe K0BX
Hi Joe,
Thanks for your reply.
If you have installed the flexradio writelog driver "WlFlexDriver1203A" off the writelog site then writelog connects to the flex using TCP/IP comms. You can tell if you are connected that way as when you select the flex in the Writelog ports menu it will not have a Comm port associated with it but will just list the name of your radio in the com port select drop down box.
If you could look in the far left column and see if you have the network name of your radio or a comx listed there, then it will tell me if we are connected to Writelog in the same way.
As I listed at the end of my post one option is to connect to writelog using SmartSDR Cat and Dax but I would like to get the IP connection working as there are many advantages to connecting in that way.
Many Thanks Andy M5ZAP
Anyone got a file to share how to use Writelog for RTTY with flex???0
Hi Rag, from the WriteLog website (under Blogs):
FlexRadio Rig Driver – WriteLog Contesting Software
It looks like they support the Flex API so setup should be very easy (I have not tried it myself). This eliminates the need to set up a CAT port. They also support RTTY contests and AFSK, but I didn't see anything specific to Flex and RTTY contests (I also didn't look very hard).
Hopefully this helps you to get started,
- 378 Community Topics
- 116 SmartSDR+
- 37 Aurora
- 923 Genius Products
