Need Rig Description File for FLDIGI - Old Posts do not work
James Del Principe
Downloaded V 1.10.8 to Flex 6500 and latest FLDIGI onto new computer. (Works great, btw) Fresh load for both. FLDIGI config/Rig/Rig CAT - rig description file says "Rig not Assigned.xml". In my old configuration on old computer, it said "SmartSDR-SliceA.xml".
I tried to follow some old posts from one year ago but the files do not work or load.
Where do I find the correct .xml file for my Flex 6500? I have configured all other items - I think - but there is no CAT control of FLDIGI. Help please. 73, Jim
You can find the xml here: https://sourceforge.net/projects/fldigi/files/xmls/flex/
BTW: Be sure you are running the latest version of fldigi.
730 -
Thank you, Gaston. I will try that now. Many thanks & 73, Jim0
Well, that did it. Almost too easy. THANK YOU !!! FLDIGI sends and receives fine now. 73, Jim1
- 247 Community Topics
- 488 The Flea Market
- 7.4K Software
- 330 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 344 SmartSDR API
- 8.5K Radios and Accessories
- 771 Maestro
- 42 FlexControl
- 727 Genius Products
- 252 Tuner Genius XL
- 84 Antenna Genius
- 224 Shack Infrastructure
- 151 Networking
- 371 Remote Operation (SmartLink)
- 118 Contesting
- 116 Amateur Radio Interests
- 810 Third-Party Software
