WSJTX hamlib time out error
Andrew O'Brien
Member ✭✭✭
Following Tim's instructions regarding SmartSDR and WSJTX 1.7 but I still get Rig Control errors . The details behind the error reveal a hamlib timeout issue . Initially CAT works as expected but after 20-30 seconds the errors pops up. Anyone solved this ?
Andy K3UK
Andy K3UK
Andy
Which Model? If it was a 6300, then this thread might be useful information.
https://community.flexradio.com/flexradio/topics/beta-and-wsjt-x
JTSDK should now be building in the missing 6300 lines.
If it was related to using the Flexradio 6xxx option in WSJTX 1.7.
It lets you use a TCP CAT port. to connect using Ethernet.73, Jay - NO5J
I had a similar issue with HRD and it ended up being Polling was glagged in hrd and i didnt know it. Unflagged that and it solved my problem.0
Thanks for the suggestions. Polling tweaks made no difference. However, things are working now after I gave up, too a break for an hour and everything worked after I rebooted software. The main changes I made were messing with the "fake it" setting in WSJTX. With that off, things improved. I know have it set as per Tim's instruction bulletin , Kenwood TS2000 set as the radio . I may try the TCP setting though, looks interesting.
Well ..glad you got results from a break..hi hi..typical isnt it with this stuff. Walk away and it comes good. Tomorrow you will turn on and something new. Its a hams life.lol. Happy new year. 731
Hello and happy new year to everyone!
I have the same issue when using Ham Radio Deluxe (actual Version 6.3.0.613) with my Flex6300 and the beta 1.10.8 - after update no connect to the radio was possible, stuck while getting / reading frequency from the radio. So I went back to 1.9.13 and all works fine again. I think there are some communication issues or variations. 73 DL2KBQ
I believe you are correct Guenther. I have been working on this issue since I updated to SmartSDR v1.10.8...
I will look into it later this week and hope to solve the issues as many of you have!
Andy (K3UK) for the last several weeks, I thought that I was the only one facing that issue: I am glad you asked it....73
- 378 Community Topics
- 117 SmartSDR+
- 37 Aurora
- 946 Maestro
- 923 Genius Products
