Problem with V 1.10.8 on PC - Laptop OK
James Del Principe
Loaded V 1.10.8 on my laptop at old QTH (good internet connection there) and took it to my new QTH. Connected to my 6500 and after it upgraded, all worked fine. Connected my old PC (that I have always used with my Flex - at V 1.6.x) and, of course, it would not 'see' the Flex. Now I have an internet connection at my new QTH so I just uploaded V 1.10.8 to the PC (after removing V 1.6.x of course) but it will not 'see' the Flex. The load went OK, no problems noted. The Flex led is blinking green. I have network activity on the switch for Flex, PC and internet modem so that seems to be good. The Flex itself should already be at V 1.10.8 from the connection to the laptop which worked just fine. Why do you think the PC no longer sees the Flex?
Couple of recommendations. Reboot the PC and do afactory reset on the radio. Everything should be fine.0
Thanks, Bob. I did reboot several times and even cut power to the radio for several minutes (this helped a past problem). I will try your suggestion to do the factory reset now. 73, Jim0
Windows or other Firewall software blocking SmartSDR from seeing the radio?
Bret
WX7Y
Confirm that all of your equipment is on the same subnet. Between locations, sometimes different routers, etc., set different IP values.0
Bret, this PC worked fine at 1.6.x. No firewall issues. I tried a factory reset and it began to load SW to the radio. We shall see.0
George, this is the same network I have always used. I think the factory reset that Bob suggested will be the answer. After the reset, it again 'saw' the radio and started to do the download to the Flex. Now the led is purple and the yellow **** chart is at 100 %. In a moment, I will cut power to the Flex and see if that restores it. I had to do that once before on another upgrade. Thanks for the responses. 73, Jim0
OK, at this point, I let it update SW for quite some time now. The yellow **** chart was at maximum for a very long time. I shut down power to the Flex and waited several minutes. I also closed SSDR. When the Flex came up it was flashing green. I rebooted several more time and did another factory reset. It eventually came back up. The Flex is now working at 1.10.8. My memory is wiped clean but that is a small price to pay. Thanks to everyone for their input. I really appreciate the guidance. 73 es Best of 2017, Jim0
- 247 Community Topics
- 488 The Flea Market
- 7.4K Software
- 329 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 344 SmartSDR API
- 8.5K Radios and Accessories
- 770 Maestro
- 42 FlexControl
- 726 Genius Products
- 251 Tuner Genius XL
- 84 Antenna Genius
- 224 Shack Infrastructure
- 151 Networking
- 371 Remote Operation (SmartLink)
- 118 Contesting
- 116 Amateur Radio Interests
- 810 Third-Party Software
