Beta and WSJT-X
It ought to always be that simple, maybe I'm just lousy at explaining.
I know one right way, but I haven't discovered enough of the wrong ways yet. What's obvious to me must not be so obvious, obviously!
SDRgadgets73, Jay - NO5J
I use 4 instances from wsjt-x 1.7. Works great on my flex 6500.
On the picture you see:
- 4 x wsjt-x 1.7
- 4 x jtAlert
- DDutil to monitor temperature
- Log4OM
Computer: Apple Imac 28" (use bootcamp to run Windows10)
That works great Jay, thanks.0
I think it might be a handshake issue with a 6300
I ran the command line
rigctl-wsjtx -m 236 -r localhost:5004 -vvvvv
And received this back
flexradio_open called
verify_flexradio_id called
kenwood_get_id called
kenwood_transaction called
kenwood_transaction: cmdstr = ID
write_block(): TX 3 bytes
0000 49 44 3b ID;
read_string(): RX 6 characters
0000 49 44 39 30 37 3b ID907;
verify_flexradio_id: Rig (ID907) is not a Flex 6000 Series
rig_open: error = Protocol error
Can someone with a 6500 or 6700 run the above from the command prompt and see if you radio ID is different than ID907
EDIT:: looking into the source code on hamlib github there is no ID for a 6300 only for
6700 ID904
6500 ID906
anything else not a Flexradio
https://github.com/N0NB/hamlib/blob/master/kenwood/flex.c
the flex6300 needs to be added with ID907 to the github source. I might try to compile a copy to play with0 -
Response from 6500:
flexradio_open calledverify_flexradio_id called
0000 49 44 3b ID;
0000 49 44 39 30 35 3b ID905;
verify_flexradio_id: Rig ID is ID905 (Flex 6500)
kenwood_get_trn called
kenwood_safe_transaction called
kenwood_transaction: cmdstr = AI
0000 41 49 3b AI;
read_string(): RX 4 characters
0000 41 49 30 3b AI0;
kenwood_set_trn called
kenwood_transaction: cmdstr = AI0
write_block(): TX 4 bytes
0000 49 44 3b ID;
kenwood_get_vfo_if called
kenwood_get_if called
kenwood_transaction: cmdstr = IF
0000 49 46 3b IF;
read_string(): RX 38 characters
0000 49 46 30 30 30 30 37 30 30 37 30 32 30 30 30 31 IF00007007020001
0010 30 2b 30 30 30 30 30 30 30 30 30 30 30 33 30 30 0+00000000000300
0020 30 30 30 30 30 3b 00000;
Backend version: 20130717, Status: Beta
Opened rig model 236, '6xxx'
Got to love open source I compiled wsjt-x and added the 6300 in the hamlib 3 and it now works just like it should
0000 49 44 3b ID;
verify_flexradio_id: Rig ID is ID907 (Flex 6300)
0000 41 49 3b AI;
0000 49 44 3b ID;
0000 49 46 3b IF;
0000 49 46 30 30 30 30 35 33 36 36 30 30 30 30 31 30 IF00005366000010
0010 30 2b 30 30 30 30 30 30 30 30 30 30 30 32 30 30 0+00000000000200
Billy
Will you be able to contact the Hamlib3 developers to get them to add your changes to the GitHub repository?
Jay, I was just thinking the same thing LOL I will try and contact someone. It was a very simple addition it shouldn't be any problem to get done.0
Billy
I could "almost" swear that there was a "stanza" to detect the 6300s in the older source that was broken. Maybe it was just overlooked during a copy/paste in the fixed source. Anyway thanks for taking the fix as far as you had to.
Real Flexers, can Git-R-Done!!!
Jay, the 6300 patch is now added to the Hamlib3 main tree It should trickle down
https://sourceforge.net/p/hamlib/code/ci/10eb19e92a95502b899273d7d2c0a86281304292/
Billy
You do good work Sir!
See folks that's how you do it.73, Jay - NO5J
So if I understand this (that is a big if at this point) without the change the Flex 6xxx setting will not work on the 6300?0
Paul, Yes you would have to use my patched version until the 3.1 hamlib3 final source code is released (its in the release candidate stage right now) and WSJT-X uses it for their release. If you have a 6300 you have 2 options use the cat control the old way as a Kenwood 2000 via Com port. Or if you would like to test out the TCP controlled beta I could post a dropbox link for the 6300 patched beta.0
If you have a chance post the link and I'll try it out with the Beta. Right now I am stuck on the last SmartSDR release with the TS-2000. I still have not be able to get the Beta SmartSDR to work on the 6300 with any setup.0
Paul, Here you go
https://www.dropbox.com/s/qp00fhtbb1r4wr1/WSJT-X%201.70%20Beta%20With%20Flex%206300%20Patch.zip?dl=0
You can copy it over top of your existing WSJTX install or extract into an new directory if you want to keep your old version intact and run the wsjtx.exe in the bin folder. Let me know how it works. I have been running (2) slices 1 on 20m and 1 on 40 all weekend via TCP cat and everything seems great no problems that I have found.2 -
Works fine on the first try. Thanks for the help.0
KB4AAA, thank you for the file. Worked fine with my 6300.
73 de Mike W9OJ0 -
I glad it works enjoy it! I pulled my hair out for awhile trying to figure out what was going on. Like everyone in the thread said it should be a 20 second setup. Now it is with the 6300 patch lol0
Yep about 20 sec. I had a little heart palpitation when I tried to transmit and nothing out and a crazy pattern on the screen, but once I realize the DAX button was not pushed I called myself a few names and made the contact. Thanks again.0
Thanks for the workaround... I just set up my 6300 / WSJT-X to work with TCP ports.0
I received an email yesterday from one of the Hamlib devs, pointing out the the 6xxx option might not be 100% functional yet because it's all still being worked on and tested. He suggested the TS2000 option would still work if we ran into problems, with the 6xxx option. At least it's controlling VFO changes and PTT, no idea what else might not be functional.
From personal experience, I can report that the DXLabs-Commander, and Omni-Rig options also work with SmartSDR. DXLabs-Commander, is also done over an Ethernet connection.73, Jay - NO5J
My Flex 6300 works well with WSJT-X via TS2000 settings and also via DX Lab Suite settings but I'm interested in getting the TCP option working . It does not work at the moment, am I correct in concluding that the rig ID issue for a 6300 has not been resolved yet ?
Andy K3UK0 -
I found KB4AAA's files , nice! Many thanks. Now to try TWO instances of WSJTX running separate TCP.
Andy K3UK0 -
Thanks, Pat and Jay. I hadn't used WSJT in any of its variants for quite some time. I decided to polish it off so I could try for AK and AL on 160 Meters. After downloading WSJT-x v.1.7 a few weeks ago I tried to do the TCP port connection to my 6500 and couldn't get it working. So I quickly went to the program's Kenwood TS-2000 mode and used a CAT Com port, and bingo! I ran it that way for a week or two. After reading your posts again today, I tried in Flex-6000 mode with "local Host:5004" (actually, I have created 4 TCP ports for future use and plan to run multiple sessions simultaneously for 160, 80, and 40 at the same time. ) All is working well at the moment. And it saved a few CAT Com ports. Thanks. Now, to write some bat files to open each one independently..... Ken - NM9P0
Ken
I've been creating TCP/Serial pairs for each slice, and sometimes with an alternate set for the A slice. It lets me do silly stuff, like running CWskimmer and Fldigi in parallel on the same signal. Drag racing the decoders sorta.73, Jay - NO5J
I typically have as many as 12-15 different CAT ports defined, and assigned to different slices. Usually one or two for each of several digi programs that I use. I haven't done much with TCP ports interfacing with the 6500, so this is a nice experiment. It will be nice when some of the other of my favorite digi programs and logging programs learn to play the TCP way!0
Any idea why when I boot the wsjtx.exe from the bin folder that contains KB4AAA's 6300 patch that is works fine for TCP control of the 6300 but if a execute a .bat file (in the same folder)
wsjtx --rig-name=SLICE_B
WSJT-X boots up OK but I cannot configure it to use a TCP port (regardless of slice )
Andy K3UK0 -
Andy
It might be a permissions problem, Do you see any difference if you right click your .bat file and run it as Administrator. Due to the security software, I run on my PC I often have to un-block connections that use network connections, even though they never cross the network devices. Windows sometimes blocks hardware access to non-admin processes too. I script WSJT-X using an Auto-It script, the same idea as a .bat file. And run into permission issues once in a while.
I also ran into problems preventing the command line options from being stripped off the the command that launced WSJT-X inside the script. Auto-It can take the command line options into account as a separate parameter. I never tried a simple .bat file.
JTAlertX should probably be able to launch it correctly, you can enter the commandline options as a separate parameter with it too.
I've done it both ways.73, Jay - NO5J
I launch my slice B either with a shortcut on the desktop with the target moded
"C:wsjtxinwsjtx.exe" --rig-name=Slice_B
or with JT Alert Auto-Start with Slice_B in the parameters
I have not have any issues with starting WSJT-X either way running both slices
if you can't get it working try and delete the Slice_B Config folder this will reset all configs for Slice B
C:UsersYour accountAppDataLocalWSJT-X - Slice_B0 -
Hi Geert,
I managed to also use multiple WSJT-X instances, and decode on several bands simultaneously using the --rig-name=**** command line option. How do you setup multiple JTALERT's, do they also need same rig-name and deparate UDP port numbers then for each instance ?
thanks es 73 de K6TE Wim0
- 246 Community Topics
- 488 The Flea Market
- 7.3K Software
- 328 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 343 SmartSDR API
- 8.5K Radios and Accessories
- 768 Maestro
- 42 FlexControl
- 726 Genius Products
- 251 Tuner Genius XL
- 84 Antenna Genius
- 222 Shack Infrastructure
- 149 Networking
- 118 Contesting
- 116 Amateur Radio Interests
- 810 Third-Party Software
