Flexradio 6500 only ANT1 + ANT2, but i need more
Geert Balsma PA3CPS
How can i connect more than 2 antennes on my flex 6500. Now i have only ANT1 and ANT2. But i need more because i have more antennes.
I now i can use a antenneswitch. But is there another "automatic" solution?
pa3cps
Geert
pa3cps
Geert
There are a few Antenna Switch's out there that use BCD control, Ameritron RCS-12, RCS-10 are two of them and there are several others, You will need to have the FTDI BCD Cable that will plug right into the back of the FLEX 6500 on one of the USB ports, check out the http://www.flexradio.com/downloads/usb-cable-interface-guide-pdf/ Document.
73's and Merry Christmas
Bret
WX7Y
I am using the Antenna Genius sold by Flex and extremely happy with it. Works great for two radios with remote operation over the Internet. It supports two radios and 8 separate antennas.
Jim, K6QE
You can always connect another antenna to the RX port for listening.... otherwise you will need an external source. you can use the new USB BCD functions to drive even legacy products like the 2/6/8 pack, Ameritron RCS and others. And of course the 403A antenna genius is designed around use with the flex 6000 series to work over your existing LAN.
Also if you happen to use expert amps or an amp that has more than 1 antenna port you could plug more in and control them there as well
I was thinking of using the MFJ-4726 antenna switch due to the fact I want to use my TS-820S with the same antennas. I have a hexbeam, 6BTV and a 160m doublet.0
Hi Rory:
Two rigs on one antenna using a (low-cost) switch? I had a bad experience with that in the past. I think most low cost switches are intended to share one rig and multiple antennas. In that configuration, there is little issue with low levels of RF hitting other ports. But, if it is two rigs sharing an antenna, it is possible there is not enough isolation between the switched ports to prevent the transmit from one radio overloading (to the point of damaging) the receive front end of the other radio.
My experience was using a switch to switch one antenna between a TS-830S and an MFJ antenna analyzer. It seemed to work fine for a day or so but all of a sudden the MFJ antenna analyzer just stopped working. I suspect the switch didn't have enough isolation or the MFJ analyzer was just too sensitive. The MFJ analyzer had worked fine for a long time without being on the switch.
Not saying there aren't good switches out there that provide the required isolation between ports. Just saying it's something to check and confirm before risking the front end of an expensive rig.
Kev
Hi Kevin, those points that I have been wondering about. I see that RemoteQTH.com has nifty build to your needs switch that I'm also looking at. https://remoteqth.com/modular-antenna-switch.php1
I use the Antenna Genius 8x1 from 4o3a.com you can hookup 8 antennas and the switch will follow the radio.0
I use a SPE Expert amp with 4 antenna ports and a rx antenna port.0
Thanks for all the reply's.
The Antenna Genius solution seems the best because you can switch ports with the SDR software.
But there is one problem. You always can connected 2 antennas at once.
Sample:
When you have 4 monoband antennas for 10-15-17 and 20 meter and i open 4 slices for 10/15/17/20 meter.
How do i handle this?0 -
A second 6700 ?
Grapje !
Perhaps You can use just one multiband antenna , on a Rx port ,something like a GPA50.
A combiner will work but you should use bandpass filters as well. It could get messy.0
I think the only solution is a Flexradio 7500 with 4 antenna ports. Or a Flexradio 7700 with 8 antenna ports.
Or to buy a log periodic antenna with a lot of bands.
- 636 The Flea Market
- 143 SmartSDR+
- 261 SmartSDR CAT
- 199 DAX
- 45 Aurora
- 957 Maestro
- 57 FlexControl
- 931 Genius Products
- 302 Shack Infrastructure
- 141 Amateur Radio Interests
