Is “fldigi on Mac” possible?
I have been contemplating installing “Boot Camp + Windows” on my iMac, but would rather dispense with Windows altogether. Also I am not really happy compiling programs!
Any advice welcome.
Hi Andrew, get the latest version of fldigi for OSX at SourceForge: https://sourceforge.net/projects/fldigi/files/fldigi/0
Very possible and very effective. I use DogPark SDR and FLDIGI for Mac. Works fine. Try Loopback (by Rogue Amoeba) as a DAX replacement to move the audio around.1
By the way, other than for updating the Flex firmware, I barely ever boot to Windows anymore.2
Hi Andrew, Fldigi works just fine on your Mac. I am currently running it on a MacBook Pro with Sierra - no problems at all. If you don't want to have to boot/reboot to get back and forth from Windows and the Mac OS, take a look at Parallels. Version 12, the latest will run Sierra and WIndows 7 through 10. With Parallels, your windows desktop is integrated right into the Mac OS desktop so you aren't rebooting to get to either OS.
Craig McVeay
N0CSM
George, does the DogPark SDR support more than one slice yet? I haven't looked at it since this past summer.
Craig
N0CSM
Just been to this location and downloaded the file, when I try to run it the operating system says You can’t open the application “fldigi-3.23.18_setup.exe” because Microsoft Windows applications are not supported on macOS. is this the wrong file?
.exe is a Windows binary, download the OSX image version instead: https://sourceforge.net/projects/fldigi/files/fldigi/fldigi-3.23.18_i386.dmg/download0
One panadapter only, with two slices.0
But then he still has to run a Windows environment. And a new Macbook won't run Windows 7 any more, so you are stuck with W10 or 8. Ick.
But if you want to run DAX, you need to use a Windows PC. If you want to use fldigi in OS X, you will need to run a sound card to the input and output of the maestro.
This will work okay. Just like most radios running digital modes. Technically DAX will be better, but I spent years using soundcards to legacy radios, and they all ran FB. Plus any chance to not run Windows is a plus in my book. Go for it!0 -
Thanks to your advice I now have fldigi up on my iMac. It believe it is running because if I type a call sign in the main display ‘Call’ box it looks up the qrz.com data, so far so good!
The next problem is with a couple of configuration forms. (I remember having problems in this area when setting up the PC version, but thankfully that is now all sorted and the system works ok.)
One configuration screen causing me are problem is - [Configure > Rig > RigCAT]
For instance in the [Rig description file] in the PC version I downloaded a file ‘SmartSDR_SliceA.xml’ what do I put here? and in the Device box, COM4 is not an option in the Mac version drop down box.
The other problem screen is [Configure > Audio > Devices]
The PC version I am using, Capture = DAX Audio RX (FlexRadio Systems DAX Audio), and Playback = DAX Audio TX (FlexRadio Systems DAX TX). The drop down menu on the Mac version is very different.
There could be other problems but until these two screens are entered correctly I dont think I am going to get anywhere.
Please can you offer further advice - please.
In OSX using the SmartSDR_SliceA.xml won't be possible, since that is a configuration file for using the Flex DAX, but, as George said, you can use DogPark SDR (in replacement of SmartSDR) and SoundFlower (which is free instead of RogueAmoeba Loopback) to route the audio between fldigi and DogPark SDR.
Links:
SoundFlower (DAX subsitute in Mac)
https://github.com/mattingalls/Soundflower
DogPark SDR (SmartSDR subsitute in Mac)
https://dogparksoftware.com/dogparkSDR.html
You will can do exactly the same as you do in Windows but in Mac. Don't give up.
73.0 -
Soundflower is not supported in the more recent versions of MacOS. It may work unreliably. Loopback or SoundSiphon are more up-to-date.0
Has anyone gotten this working with iCAT and iDAX from DL3LSM?1
Yes! Newly released version 1.08 support s DL3LSM's xDax AND there is now support for the new SmartLink protocol as well! Life is good/better/best with Mac and DogparkSDR! https://dogparksoftware.com/dogparkSDR.html2
- 375 Community Topics
- 104 SmartSDR+
- 425 SmartSDR for Mac
- 999 Third-Party Software
