Smartsdr ios cluster add
WV9L
Can someone help me figure out how to add a cluster location thats closer to me, to help filter out the spotter dx locations? I have tried adding some but i dont see a save button in smartsdr ios. So the settings i put in never save. Thanks!
Hi Jeromy,
thanks for your post.
Seems there is a small glitch in the App but if you follow these steps, you can add a new Cluster Server:
- Open the DX Cluster Tool
- Tap on Settings
- Tap on the Server line (defaults with DX Summit)
- Tap on the + sign at the top
- Enter a Title, the IP Address or domain of the Server you like to add and the port
Now comes the glitch: Instead of tapping on the next field, the Type, first tap on Return or the displayed Done button and leave the screen using the back button - this will save the screen and dismiss the keyboard
- Now select the newly created entry by tapping on the list (possibly you need to scroll down) and once selected it receives a check mark
- You can now continue to change the Type by hitting the edit button
The issue on this screen is, that changing only the type will not causing to save newly created Server entries.
Sorry for this bug. I will fix it with the next version but I think the workaround above will do until then.
Probably I (and others) didn't ran into this because most of the time I am using Standard Skimmer type Servers so I never changes the type and then, everything works as expected.
vy 73,
Marcus, DL8MRE
I got that to work, but cant seem to get any local ones to ever actually connect. Ive tried several across the USA. Id like to use US ones to hopefully help filter out ones that arent spotted by US hams. Anyone have any advice or reccomended clusters?0
Heres message i get:0
VE7CC works. Good for western USA.0
Im in IL but its a good start. Thanks for the tip. 730
- 342 Community Topics
- 611 The Flea Market
- 7.9K Software
- 6.3K SmartSDR for Windows
- 406 SmartSDR for Mac
- 265 SmartSDR for iOS
- 249 SmartSDR CAT
- 186 DAX
- 373 SmartSDR API
- 9.2K Radios and Accessories
- 20 Aurora
- 197 FLEX-8000 Signature Series
- 919 Maestro
- 889 Genius Products
- 322 Tuner Genius XL
- 116 Antenna Genius
- 283 Shack Infrastructure
- 199 Networking
- 137 Contesting
- 746 Peripherals & Station Integration
- 138 Amateur Radio Interests
- 967 Third-Party Software
