Maestro Velcro Worn Out
My Maestro battery Velcro strips holding the battery in have lost there grip. This allows the battery to move around in the battery compartment. Replacing the Velcro strips appears to involve removing security stickers to access the screws holding the back cover. This would void my warranty. It would be a shame to send the Maestro to the factory for this simple procedure.
Thoughts?
ka7gzr
Thank you for reminding me,
I also have the same issue.
My Maestro, usage has been minimal but the Velcro needs to be replace or have the internal battery charge internally.
I don't have a Maestro or know about voiding the warranty but if the Maestro is using the type of Velcro closures I'm thinking of I'd suggest considering something like 3M Dual Lock Reclosable Fastener (googleable). There are different versions with different holding ability but I think they are all made for long-term on/off use without failing.
I use some on my Motorcycle to hold gadgets to the dash. One thing fell off once but it's a Harley. It's a pretty challenging environment.
Kev K4VD0 -
Seems a talk to FRS guys or going to a Pad-on-battery and pad-in-Maestro-pocket are the suggestions?
Wondering how the original **** is secured, as it could be possible to use it as a pull to work a new one through?
Hmm... will look at mine tonight.
Steve K9ZW
Looks like they are threaded through the case and should be easy to replace. I agree with Kevs comments regarding getting some higher quality "Velco" if I replace it. The thickness and width of the strips are critical in this installation.
Jim
ka7gzr0 -
You might try to cut some foam and shape it to the compartment and battery and you won't need to worry about Velcro or warranty.
Good Luck
Larry ke2yc
Kevin K4VD
This particular type is to thick and hard to pull apart. The regular black Velcro may be better. Or, as other have suggested a padded foam etc... May be better.
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 71 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
