1.10.8.30 CAT problem - CAT works only when restarting manually
DH2ID
Member ✭✭✭
CAT takes quite a long time to autostart when starting Windows 7 HP 64bit.
Starting MiniDeluxe it can't find a CAT port, WSJTX and HRD DM780 do not get
CAT and PTT COM ports from SmartSDR CAT.
Closing SmartSDR CAT and restarting it manually solves this problem.
This behaviour is new with 1.10.8.30 and has never happened before.
Eric, the problem is that the user is starting DDU by a shortcut in the Startup directory of his start menu and its coming up before CAT has initialized and defined its vcomm ports. Steve Nance has recommended people to not start DDU up in the Startup directory for this reason. On the computers I install, I create a task that starts up DDU 2 minutes after startup and checks every 2 minutes to see if its running (and if not, it starts DDU up). If anyone needs assistance on setting this up, I will be glad to help.
Neal, SmartSDR CAT and DAX are in my autostart folder and have started without
problems until I installed 1.10.8.30.
Some time after CAT and DAX have started I run a batch file which starts MiniDeluxe, SmartSDR, FRStack, HRDLog and WSJT-X.
This has worked all the time. I hope it will work again with an update.
BTW I think you mean DDUtil by "DDU", which I can't use as it does not work with
WSJT-X.0 -
Alex, I started seeing this over a year ago on Win7 and not on alpha/beta releases but production releases. Also, these were high-performance machines, not i3s, etc.
Its okay to run CAT and DAX in the autostart folder, its where Flex puts them. Just go to the task schecduler (in the Admin section of your control panel) and create a task that starts 3 minutes after login to execute your script. If CAT hasn't fully come up in 3 minutes, then change the delay in your task to 210 seconds, etc. Keep bumping it up until it starts correctly and forget about it.
Yes, DDU stands for DDUtil, I just get tired of typing the full name HI!1 -
Ok, I took Neal's good advice and created a batch file, which I compiled:
@echo off
cd C:Program FilesFlexRadio SystemsSmartSDRDAX
start DAX.lnk
cd C:Program FilesFlexRadio SystemsSmartSDRSmartSDR CAT
start Cat.lnk
cd C:Program Files (x86)MiniDeluxe
start MiniDeluxe.exe
cd C:Program Files (x86)Ham Radio Deluxe
start HRDLogbook.exe
cd C:Program Files (x86)FRStack
start FRStack.lnk
cd C:Program Files (x86)HamAppsJTAlert
start JTAlert.exe /wsjtx
start SmartSDR.exe --serial=XXXX-XXXX-XXXX-XXXX
exit
(I used links for some programs to start them minimized)
Now all is OK again, Problem soved!0
- 650 The Flea Market
- 154 SmartSDR+
- 50 Aurora
- 964 Maestro
- 938 Genius Products
