CwSkimmer 6300
Mike NN9DD
I am running at Flex 6500 and a Flex 6300 different QTH and the settings are exactly the same and should work as it sits.
What I am seeing is that when I start SDR Bridge and skimmer the 6300 goes instantly into transmit. The only way to stop it is by shutting the radio down, The MOX button is lit and hitting stops the transmit for about as long as you hold the button down. It then returns to transmitting.
Not sure what I am missing but any thoughts would be helpful
N9DFD
N9DFD
That is NOT happening here with my 6300 , are you sure the SMARTSDR CAT settings are correct ?
Andy K3UK0 -
I suspect a problem may be with the CWSkimmer IQx.ini files SDR-Bridge uses since SDR-Bridge is telling the radio to go into transmit.
Also, make sure you have the latest version of SDR-Bridge loaded too.0 -
Skimmer 1.91 and bridge 1.5.1. They should be the latest its working on the 6500 not the 6300.
I suspect your right with bridge and skimmer as I have turned on TX inhibit in the settings and I can copy fine
I will uninstall bridge and skimmer and reinstall it.
You may need to remove the ini files from the %PROGRAMDATA%W2RF folder before reinstalling.0
Ill try that because a straight reinstall did not work
Thanks Tim
That Did it
Thanks Tim and have a great holiday
Tim, You're OK don't care what they say about you
Thank for all you do. If you're travailing today BE SAFE.
73's Dan
Thanks, Dan. Here is wishing a happy and safe Thanksgiving to everyone.0
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 70 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
