CwSkimmer 6300
Mike NN9DD
Mike NN9DD Member ✭✭
edited October 2019 in Third-Party Software
I am running at Flex 6500 and a Flex 6300 different QTH and the settings are exactly the same and should work as it sits.
What I am seeing is that when I start SDR Bridge and skimmer the 6300 goes instantly into transmit.  The only way to stop it is by shutting the radio down,  The MOX button is lit and hitting stops the transmit for about as long as you hold the button down.  It then returns to transmitting.
Not sure what I am missing but any thoughts would be helpful
N9DFD
  • Andrew O'Brien
    Andrew O'Brien Member ✭✭✭
    edited November 2016
    That is NOT happening here with my 6300 , are you sure the SMARTSDR CAT settings are correct ?
    Andy K3UK
    edited March 2017
    I suspect a problem may be with the CWSkimmer IQx.ini files SDR-Bridge uses since SDR-Bridge is telling the radio to go into transmit.
    Also, make sure you have the latest version of SDR-Bridge loaded too.
  • Mike NN9DD
    edited October 2019
    Skimmer 1.91 and bridge 1.5.1.  They should be the latest  its working on the 6500 not the 6300.
    I suspect your right with bridge and skimmer as I have turned on TX inhibit in the settings and I can copy fine
    I will uninstall bridge and skimmer and reinstall it.
    edited December 2016
    You may need to remove the ini files from the %PROGRAMDATA%W2RF folder before reinstalling.
  • Mike NN9DD
    Ill try that because a straight reinstall did not work
    Thanks Tim
  • Mike NN9DD
    That Did it
    Thanks Tim and have a great holiday
  • Dan -- KC4GO
    Dan -- KC4GO Member ✭✭
    Tim, You're OK don't care what they say about you :)
    Thank for all you do. If you're travailing today BE SAFE.
    73's Dan
    Thanks, Dan.  Here is wishing a happy and safe Thanksgiving to everyone.
