integrate n1mm and cw skimmer
AH0U
I am using a 6700with CW Skimmer and N1MM but have to use the N1MM Bandmap to load the call sign and freq. into the program which is fine but right clicking and find the turn rotor tab is a pain... but the real challenge for me is having to click on a call sign in Skimmer then going over to the bandmap and again clicking thee to load the call into N1MM... is there an easier way???
Are you using sdr bridge? http://www.qrv.com/sdrbridge.html0
Yes I SDR bridge for CW Skimmer and it works fine, but I want to have CW Skimmer talk to n1mm and I don't see how to do that.
bc
I meant to check today but haven't been able to. I remember there was a setting (telnet server maybe?) that provided that connectivity to share callsigns between the programs, but I can't recall if the top of my head. I will try to check tomorrow.0
CW skimmer has the telnet server built in.
Connect to that in N1MM+ via the telnet settings.
If you want to combine the internet cluster(s) and skimmer or multiple skimmer instances you can use WintelnetX by K1TTT.
Once you have the telnet setup, the decoded calls will show up in your bandmap.0 -
I have tried that but still get,,, unable to connect messages in the n1mm telnet screen.... How have you set the n1mm telnet dialogue??
Tnx, AH0U
Go into Windows -> Telnet then go under "Clusters" tab. Then click "Edit list"
Double click an empty row and put the skimmer's info in there.
Then click OK and go back to the main window and select the skimmer you created.
Then click "Connect"
It will throw you back to the first tab and you will be connected:
And you're done. The entries will show up in your bandmap.
Ria,
I think that what he means is that he wants to be able to click on a call
on the Skimmer panel and have it go into the Entry window in N1MM.
It works fine if using the band map... But I also can not get the call
to go into the N1MM entry window directly from the Skimmer Panel.
But the advantage of using the Band Map Panel is that N1MM will
Gray the contacts that you have already made and highlight the
Multipliers .
Ken W9IE (If I am wrong please let me know)0 -
There is no way to do that with skimmer. You have to use the band map.
If Bridge is connected to Skimmer, clicking the Skimmer bandmap causes the Radio to QSY. (This action is independent of loggers.) What happens next depends on which logger you are using.
If the logger is N1MM, CAT from the radio causes N1MM to QSY. But since N1MM is not connected to Bridge, there is no further action:- The callsign is NOT transferred from Skimmer to N1MM.
- The N1MM status of the callsign is NOT transferred to Skimmer.
- WriteLog receives the callsign from Bridge.
- Bridge queries the callsign status (worked, new, mult) from WriteLog.
- Bridge sends a color-code to Skimmer that is used in the bandmap.
I have tried and been unsuccessful in getting N1MM developers to cooperate on this issue. Any encouragement you can give them will be greatly appreciated!
In the mean time, WriteLog is a great solution. I recommend it highly.
73 Ed W2RF
2 - The callsign is NOT transferred from Skimmer to N1MM.
Yes works perfectly in Writelog single click from either the skimmer copy window below and/or the Skimmer bandmap. Also from the Writelog Bandmap fed from dx cluster.
N1MM no only as Ria had stated.
It will eventually populate the N1MM callsign entry window via the N1MM Bandmap only, too many extra steps getting there. It would greatly improve the N1MM / Skimmer experience if they were to get with Ed on this. So much not being realized with the combination of these two. Terrible shame.
I heard some place and I totally agree "programmers rule"! Come on N1MM guys, please make the magic happen.
Ed W2RF, compliments for everything you have done, thank you!
I see this was posted a year ago. Has there been any movement by N1MM+ to implement this??
Kent
N6WT
Ria, any idea how to get to filter spots so it only sends contact calling CQ or Test. Right now it is send every call it gets. I know how to do CQ is there away to add test as well Mike NN9DD0
Thanks Tim I have it working with Wintelnetx running skimmer spots as well as ve7cc feed
NN9DD0
- 383 Community Topics
- 638 The Flea Market
- 144 SmartSDR+
- 434 SmartSDR for Mac
- 273 SmartSDR for iOS
- 261 SmartSDR CAT
- 200 DAX
- 958 Maestro
- 934 Genius Products
- 342 Tuner Genius XL
- 303 Shack Infrastructure
- 142 Amateur Radio Interests
