Flex 6500 broken by static electricity
Den
Hi !
Our team is now in the expedition on North Pole. Yesterday we prepared a position sharply went heavy hail. Enough for 2 seconds and flex decreased sensitivity. There is no way to return to the mainland and send you to repair the radio. We had to open the radio and examine the generator and oscilloscope. We have found the item (IC73 on plate) in SC-70 package, which brought up the receiver chain to ground bus.
After removal of the defective item and reception sensitivity recovered. Can we at your own risk transfer radio transmission? Full repairs done when returning to the mainland.
Burnt element is - PE4259?
Tnx!
Tnx!
QRX... checking... response within 30 min1
IC73 is not a PE4259, it is a TI ESD protection diode on the receive input. You can operate without this part, but it protects more expensive parts further down the line that are more expensive. There is still one more of these before you get to the ADC. I would probably operate without it, but try to protect the front end from any further ESD events.2
Use high resistance bleeder type lightning protection device so static will bleed off rather than damage the rig.
Tnks!!!!!!!!!!!
thanks for the answer, you are very helpful, we will continue to work at your own risk. What type of diode TI ESD protection. When we return, we replace it by yourself, it will be easier for you and for us.
Thank you!1 -
Or use loops or folded elements that are at ground potential for DC.
Andrew VK5CV
Quarter Wavelength Coaxial Stub at operating band Length of Coax
Grounded at one end while the other end goes to a 50 ohm Tee at Antenna Port will DC ground Input but allow RF out to protect Radio
Electrical Open at Radio but at end of Quarter WaveLength Stub is Shorted will help greatly !0
- 245 Community Topics
- 490 The Flea Market
- 7.4K Software
- 327 SmartSDR for Mac
- 243 SmartSDR for iOS
- 224 SmartSDR CAT
- 163 DAX
- 347 SmartSDR API
- 8.5K Radios and Accessories
- 768 Maestro
- 42 FlexControl
- 727 Genius Products
- 251 Tuner Genius XL
- 84 Antenna Genius
- 222 Shack Infrastructure
- 149 Networking
- 118 Contesting
- 116 Amateur Radio Interests
- 811 Third-Party Software
