Has something changed, or did I stumble on to a bug.?
Jay Nation
In the past, I've been storing custom bandwidth filters in SSDRs memories. ie. RX Filter Low = 0 Hz, RX Filter High = 2000 Hz. When I wanted to use that filter, I just selected it from the memory window. Today whenever I select that memory, it sets the filter to RX Filter Low = 500 Hz, RX Filter High = 2500 (As if I had selected a 2K filter with the DIGU mode 2.0K button. Is this now the intended behavior?
With WSJT-X I have the choice of either JT65 or JT9 individually, or JT65 and JT9 combined. I use a 4K filter 0 Hz to 4000 Hz when I'm using the combined option. but I use a 2K, 0 Hz to 2000 Hz filter width for either of the single mode options.
I can still save that 0 - 2000 Hz Filter with FRStacks, or DDUtil. But, I had been able to do that with a saved memory too.
The weird part is if I set a 0 - 2000 filter width and then Add it as a new Memory. It gets saved as a 0 - 2000 Hz filter. But when I select that new memory it sets a 500 - 2500 Hz filter now.
Why?
SDRgadgets
Why?
SDRgadgets
73, Jay - NO5J
I'm not seeing the same Jay. My saved filters seem to be restored properly including the 0-5000 Hz filter I use for JT65/JT9.
If you export your memories and check it out as a text file maybe you'll find a corrupted line causing the problem?
By the way, you don't run DXLabs Commander, do you?0 -
I am also seeing my same filter limits that I previously set.0
We have an existing defect for this behavior listed in our bug tracker (#3388). I have added your problem description to the defect details. Thnaks for the info.0
Kevin
I'm aware of Commander's weirdness with the filters, But what I'm dealing with at the moment is something in SmartSDR. It's repeatable when only SmartSDR is running.
I'll play around with it some more, Today when I first opened SmartSDR selecting the 0 - 2000 Hz filter worked, the first time I selected it, but it quit working again on the second or third try. It's not really a bother, FRStacks is often easier for me to get to, I've got FRStacks favorites saved for most of the digital band plans. I was really just curious if it was happening to everyone, some, or just me.
SDRgadgets73, Jay - NO5J
Ok an additional note.
If I set the RX Filter Low to 3 Hz or greater then it will set a 3 - 2000 Hz filter. But RX Filter Low = 0, 1, or 2 Hz filters are setting 500 Hz - 2500 Hz.
Almost, but not quite as good,
- 328 Community Topics
- 594 The Flea Market
- 7.8K Software
- 6.2K SmartSDR for Windows
- 396 SmartSDR for Mac
- 260 SmartSDR for iOS
- 246 SmartSDR CAT
- 179 DAX
- 369 SmartSDR API
- 9.1K Radios and Accessories
- 15 Aurora
- 161 FLEX-8000 Signature Series
- 909 Maestro
- 51 FlexControl
- 873 Genius Products
- 312 Tuner Genius XL
- 115 Antenna Genius
- 278 Shack Infrastructure
- 196 Networking
- 135 Contesting
- 724 Peripherals & Station Integration
- 136 Amateur Radio Interests
- 944 Third-Party Software
