Connect Flex 1500 to Elecraft KXPA100 amplifier
Jose B Rivera
I wish to connect my Flex 1500 to my Elecraft KXPA100 amplifier. I wish to know if there are any ready made to buy cables out there which will connect these two units? I am guessing it has to go through the flexwire port. I solder terribly so I can't do it myself. de N2LRB
Have you researched the manuals for both pieces of equipment you are wanting to connect? I think you will find your answer quicker than I can type it all out.
HI Jd, I am looking to buy a ready made cable so that the radio keys (ptt?) the amplifier. If that is the answer. If you know the answer give me a hint. Am I looking for a cable or can I just hook the coax?0
You are going to need to build your own or have someone do it for you. Standard RCA cable on one end to the KXPA 100 to 2 pins on the DB9 into the Flex 1500. Pin out is on page 18 of the Flex 1500 owners manual. No body I can find is making a ready made cable for your application. Making stuff is the fun part of this hobby!
w2ihy made this cable
73 elan g0uut0 -
Jd, thanks again for getting back to me. You wrote what I did not want the answer to be, LOL. I am absolutely terrible, at creating such things. Which is why I wanted to purchase one. When ordering my Flex 1500 yesterday, I never thought that the connection between the radio and my Elecraft KXPA100 would be a problem. I may not have ordered the radio. QRP is not for me. But since I already have an amp, I figured why not use it? Silly me. I wonder why Flex chose such a connector when others use RCA on both ends? Again thanks! I will have to create the cable and hope it will work.0
Elan, I checked and will call W2IHY today to see if maybe they can create the cable. Thanks.0
Julius (W2IHY) makes primarily audio cables to interface the FLEX-1500 to his audio products. Although he may be willing to make one.0
Update: I e-mailed Julian and he does not make that cable. I guess I am gonna have to make my own. You all don't know how much I dread the thought. There is a part I read about some resister too. I know nothing about electronics. Woe is me. Will let you know what happens. Thanks for all your responses.0
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 71 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
