MAESTRO WI FI PORTABLE
Kent Hufford
I need wi fi out of my FLEX 6500 when standalone… a router?
With the 6500 in the shack I have a rj45 cable connected to my wifi router. The Maestro can see this fine. However, if I take the 6500 and the Maestro somewhere else. I can connect the 6500 to the Maestro via a real RJ45 cable.
But, I want to connect the 6500 via wifi to the Maestro. What kind of wifi router? Can I use? Cannot setup a regular wifi router with only a 6500, and don’t want to drag a PC with it.
Somewhere I thought I saw some neat device to do this, LIKE BELOW?
TP-Link N300 Wireless Wi-Fi Mini Router, Range Extender, Access Point, Client Modes (TL-WR810N)by TP-LINK
Kent -
Do you need to use a WiFi router with no computer at all? It can be done, but you will need to configure the router with a PC, at least at first. You will have to set up the WiFi name ("SSID") and password, at a minimum. After it's set up, you should not need the PC again. Most any WiFi router should work (but some are better than others - read https://helpdesk.flexradio.com/hc/en-us/articles/208726766-WiFi-Requirements-and-Performance-with-Ma...) The 6500 does not know how to work with a WiFi adapter, so you have to use a wired Ethernet link to the router. The router will talk to the Maestro over WiFi.
The thing is, to use a WiFi connection, you need to establish an actual network, though you don't have to have Internet access. This normally involves a router, and routers do require some configuration with a PC.
It would be helpful if the Flex 6x00 supported a USB or Ethernet WiFi dongle, peer to peer with Maestro. As we say, "it's only software."
73 Martin AA6E0 -
One possible option to a PC for configuration is your Android or Apple cell phone. I was able to configure my R7000 after downloading an application to my Nexus and then connecting with WPS. From there, I pretty much could configure it any way I like.
The advantage here is that you can operate without a computer and, if a reconfiguration or tweak is required, you can do it with your phone.
In my case the application is called NETGEAR Genie. Other vendors may have their own app.0 -
These days a smartphone pretty much is a PC. There is an Android app for the Asus router that I use - an RT-N66U. (That works well with my Flex gear.) The point is you do need a smart device to set things up.0
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 70 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
