SmartSDR for Maestro v1.9.9 Winkey emulation still problematic
Mike_N1MD
I have been using the Winkey emulation in SmartSDR off and on since it was released with N1MM+ in RTTY and CW contests.
Though there have been great strides in working out the bugs, in my opinion it is still not ready for prime time. I will go back to my USB Winkeyer again.
When using a mouse to activate contesting functions and macros with the emulation, there is a perceptible lag between click and execution. Often one needs to click on the function buttons twice in order to send the contest message. The issue disappears if I use the USB Winkeyer.
I have tried all kinds of adjustments to the Winkey screen in N1MM+ to overcome the latency when using the SmartSDR CAT Winkey emulator but no joy.
I have a 6700, a very fast and nimble PC with factory installed, fresh Win 10 and the machine is used for nothing else except radio operation/logging. The Maestro is on Ethernet to a switch that connects to my WiFi.
If anyone has any fresh ideas, I am eager to read them.
Mike N1MD
Mike N1MD
Have you tried the Maestro directly to the switch without going through WiFi? Just to make sure the latency is not in your network.
I am not saying that is the solution, just one more test that might shed light to where the latency might be.0 -
Yes and no difference.
Tnx for your response and thoughts!
Mike0 -
Are you using the latest updates for N1MM+?0
Yes -- 1.0.5924 released on 20 Sep 20160
We had a bug that is very similar to this identified in Alpha, That was resolved in 1.8.5. Is this delay not there when you actually press the F key on the keyboard? ONLY when you use the mouse on the GUI?
Chris, I need to test the F keys. I was so focused on the mouse issue that I neglected to test the function keys.
I am all set up for the CQWW RTTY contest starting tomorrow so do not want to reconfigure away from the hardware Winkeyer to the software emulation until that contest is over. I will test the F keys early next week.
Thanks for your help.0 -
No problem.. just drop me a note when you are able0
Oh and good luck in the contest! Have fun and share your experience afterwards!0
- 245 Community Topics
- 490 The Flea Market
- 7.4K Software
- 327 SmartSDR for Mac
- 243 SmartSDR for iOS
- 224 SmartSDR CAT
- 163 DAX
- 347 SmartSDR API
- 8.5K Radios and Accessories
- 768 Maestro
- 42 FlexControl
- 728 Genius Products
- 251 Tuner Genius XL
- 84 Antenna Genius
- 222 Shack Infrastructure
- 149 Networking
- 118 Contesting
- 116 Amateur Radio Interests
- 811 Third-Party Software
