Display tab settings
What are the default settings for the display tab in the smart SDR window?
  • Corey/ KC0YNS
    Corey/ KC0YNS Member
    edited February 2017
    Brian, You can always to a manual reset on the 6300 if you haven't set up any profiles yet.
  • Tim - W4TME
    edited April 2020
    Average = 50
    FPS = 25
    Weighted Average = OFF
    Gain = 30
    Black (level) = AUTO
    Rate = 80
  • Andy W3LI
    Andy W3LI Member ✭✭
    edited April 2020
    As per Tim's numbers above I have set those in the display settings. Tim, have you changed your numbers?
    I have followed the procedure in the SSDR manual but the display is not what I would expect. Not very pretty???
    Anyone else have numbers to try?
    W3LI...
