Display tab settings
Brian Matthews
What are the default settings for the display tab in the smart SDR window?
Brian, You can always to a manual reset on the 6300 if you haven't set up any profiles yet.0
Average = 50
FPS = 25
Weighted Average = OFF
Gain = 30
Black (level) = AUTO
Rate = 802 -
As per Tim's numbers above I have set those in the display settings. Tim, have you changed your numbers?
I have followed the procedure in the SSDR manual but the display is not what I would expect. Not very pretty???
Anyone else have numbers to try?
W3LI...0
- 683 The Flea Market
