What I would like to see for my Maestro
You can program the Antenna Genius to follow the Flex radio automatically.
That only works after you use the PC to turn on the AG and boot the AG software.... You can't control the AG without a PC0
My Antenna Genius follow my radio even with my Maestro0
In the AG instruction show to setup that up.0
page 16 of the owners manual talks about setup of the Flex Radio
Mine does too after I use the PC to boot the AG software... I also need the PC to shift antennas. When I have two or more antennas for the Saane vand0
Can you tell me the page number as my manual says I need to boot the AG software before the Naestro can change babds0
Of of which manual?? AG, Naestro IR the Flex???0
The AG0
I don't think you understand my post.... You MUST boot the AG software from a. PC before the Maestro can see the AG ... Once you have run the G software on your PC then the AG will follow the Maestro UNLESS you have more than one antenna for the same band then you must go to the PC to correct the AG setting chosen by the Naestro... There is no way to use. Naestro with an AG without first using a PC to ru. the AG software.... It's a pain if the Naestro is not in the same room as the PC . Tbx fer your response but a PC is required0
You can't program the AG that is the problem.... You can only program the AG software which means you must run a PC .... No PC, no software... No software the AG will just sit there no matter what the Maestro does. Tnx Es 73, AH0U0
Ranko has said later software releases for the Antenna Genius and Station Genius are intended to be more autonomous. No time frame given. 73 Steve K9ZW0
I know and I have great faith in him and his gear... Great customer service but I don't think it is totally within his control... Seems like the Flex folks need to get involved too.... It would make things a lot slicker0
Ranko didn't leave the impression that he had anything less than 100% support from FRS. I understood that all the FRS hooks needed were exposed to enable the topology change down the road. FRS also hinted that longer term goals included moving certain software functions from the station's PC to the Flex-6000, again reducing the need for an external computer. To answer your question more clearly, based on what we know it is not possible with the current general release software from FRS or 4o3a. Future releases beyond SmartSDR 1.9.7 and 4o3a AG 3.0 and SG 2.0 may get to there, but it is isn't possible to say when or offer absolutes. 73 Steve K9ZW0
- 372 Community Topics
- 94 SmartSDR+
- 424 SmartSDR for Mac
- 270 SmartSDR for iOS
- 937 Maestro
- 54 FlexControl
- 997 Third-Party Software
