SSDR v 1.9.7- A problem
Tom
Upgrade went well, Maestro and radio completed its update. Everything seems to be OK.
Today, when I switched radio and Maestro I note the following:
On Maestro frequency cursor and associated filter width area are missing
When Maestro is switched on, it connects to the radio itself, without usual steps like radio selection , etc.
The same problem occurs when when I use my PC connected to my Flex 6700 Frequency cursor and filter width area are missing.
Apart from this, radio works properly. My OS is Win7
Any suggestion what is wrong?
Tom, SP7WT
Tom, SP7WT
I do not understand your issue. Can you take a screenshot and post it?
You can easily do it by pressing Ctrl+PrintScreen in your keyboard.
Or you can use the windows "Snipping Tool"
Once you have the picture, you can drag and drop it directly into a response here.0 -
what steps have you taken to correct it?0
Greenshot is a great screen capture tool as well. A picture would really help.0
Tom,
1) In 1.9.7, some startup steps are bypassed if you only have one Flex on your network..
2) Are you saying that the cursor and filter indicators are missing but the radio seems to be receiving ? Is the slice off of the panadapter? Or are there no receive slices active? If you can not add/remove a slice, try a reboot/power cycle of the radio. If that still fails try areset of the radio to factory defaults...
AL, K0VM
I saw what is probably the same issue this morning; I run with 8 panadapters and 3 of them didnt show the slices.. The slice was off screen; Looked like the pana initialized on some oddball freq and I had to double click on the slice to bring it in view.. If it happens again I'll take a screenshot.
I am pleased to report that the has gone. I do appreciate Al's , K0VM comments about a different Maestro start up routine if only one radio is on the network.
I left my radio and Maestro running for a few hours, then restarted again. Everything seems to be OK now.
While experiencing this problem I also noted some odd frequency values on slice display.
Interestingly, the radio was working as normal all the time
Tom, SP7WT
- 107 SmartSDR+
- 427 SmartSDR for Mac
- 256 SmartSDR CAT
- 942 Maestro
