BandInfo ver. 1.09 available ...
Gary L. Robinson
BandInfo ver. 1.09 is available for download at : http://oliviamode.com/wb8rol_xtra.htm
***IF you have already installed BandInfo ver. 1.07 it is recommended (if you modified the freqinfo.csv file) to BACKUP a copy of the freqinfo.csv in the BandInfo install folder and then uninstall ver. 1.07 before installing ver. 1.09
BandInfo ver. 1.09 adds support to customize the size (both width and height) for the main program window, the font size, and font color (forecolor and backcolor). The settings.csv file holds the settings to change the items aforementioned.
I also changed the DEFAULT settings (when it first runs before modifying) to a smaller width starting size and font color.
An additional method for making the program stay on top was also added. Hopefully this helps to stay on top for everyone.
---Gary WB8ROL
---Gary WB8ROL
Hi Gary,
Good improvements. However, (you guessed it), the stay on top does not work on my Win 10/2 screen. I work around this by reducing the vertical size of the Flex screen at the top and placing your window in the narrow space.
I've done a little coding in C++.NET and I don't understand why this "stay on top" does not work either.
I'll play with this for a while and you keep trying.
Roy - W5TKZ
THANKS Gary!!! I'll give 'er a try!
It works GREAT!! and stays on top! (also using WIn 10)0
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 71 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
