Ethernet to Firewire adapters
Bob Meadows
Will they work? I am using a Dell 6430 laptop, and the PCMCIA card is toward the front on the right side. The cards sticks out way to far, and with the Firewire cable plugged in it makes it that more less convenient to use the laptop. Can a guy buy a Ethernet to Firewire adapter and have it work. I sure would like to be able to run the radio using the Ethernet port. I have seen these adapters, and they just plug into the Ethernet port and the Firewire cable plugs into the Firewire port on the adapter. Sure would make it nice this setup would work. Anybody tried this yet?? TNX, Bob
It would be nice, if that were possible. Can you post a link to the Firewire to Ethernet adapter your looking at? I'd like to look it over too.
SDRgadgets73, Jay - NO5J
The answer is no. The only mixed physical layer device known to interface with Firewire is a Thunderbolt interface0
- 391 Community Topics
- 664 The Flea Market
- 441 SmartSDR for Mac
- 206 DAX
- 60 Aurora
- 298 FLEX-8000 Signature Series
- 974 Maestro
- 948 Genius Products
- 348 Tuner Genius XL
- 127 Antenna Genius
- 308 Shack Infrastructure
- 216 Networking
