Any clue on this noise
Mike NN9DD
Looking for guidance as to may be causing this noise. The op is running a 6300 1.8.4 win 10. This QTH is in a new community with close houses in central Arizona. The noise is about 90hz apart and repeating on 20 meters
I often get the same thing on 20m reoccurring closer to 50-60hz across the band. I've yet to find a solution or a source.
Rick, W2JAZ
Mike,
My first guess is you or a neighbor's air conditioning system has a variable speed fan. anything further will require more detail from you, like does the noise cycle on and off. Hot tub? Swimming pool pump? Good luck finding it. I purchased a direction finding loop that has helped me find my noise sources.
Roy - W5TKZ0 -
Check for Solar Panel roofs in your area.. Got the same exact issue here. about 60kh apart. Point my 20m yagi at the house at the corner and up comes the noise.
Barry K6ZA
I had the same thing that I traced to my HVAC outside unit.
So far, at least I know the source, but not the solution.0 -
Make sure that your home is not the source first. Note that the spectrum appears to be a narrow signal, not random noise. Although I refer to the signal as "noise", it is not broadband noise. Switching power supplies are a starting point: Remove the power to your router power supply first. If the noise persists, do same for all other switching supplies in the home: unplug TVs, Radios, telephones, wall warts.... Many innocent devices have internal switching supplies that are suspect.
If no luck, turn off circuit breakers one room at a time to see if the noise is caused in that room. Run PC off backup power for your station room. If possible, remove computer power (this may require a battery powered radio tuned to the noise).
If is not generated in your home and if you have a directional antenna, rotate it to find a null. If you find a null, the noise is being generated in the direction of the null. On Yagi antennas (beams) this is the direction perpendicular to the elements. If you were at the end of one element and looked along the element toward the other end, you are facing the direction of the noise. It could be in either direction...the direction you are looking or the direction behind you.
If you have succeeded in finding a null, and your antenna is directional and rotatable, find the direction where the noise is strongest. That will be broadside to the elements and coming from the direction looking broadside from the longest element to the shortest element.
If you have identified the direction of the noise, use a portable radio preferably with a directional antenna to move in the direction of the noise to find the location where it is strongest. This is best done with a radio having a visual (meter) indicator of the noise amplitude.
If you have gotten this far, you are on the right track if the noise is being radiated from outside your house, but you probably will need a radio equipped for "fox hunting" and a bit of "Elmer" assistance to continue.
Another approach, not quite so effective is to identify when the noise is present and absent, if the noise changes frequency, changes amplitude, is periodic, goes away for periods of time, goes away over night,... These clues are useful in identifying what type of device is operational in that fashion.
Good luck, Mike. I hope you were able to stop at the first paragraph.
Stan W8NNX
WB5RVZ,
For your info, There is an article titled "A Tale of Two Air Conditioners" in the August 2016 edition of QST Magazine. This might give you some information on a solution.
Roy - W5TKZ0 -
Thanks to all who have provided comments. This is my fathers QTH I suspected he would have challenges and there are a lot of AC and Solar around as it is Arizona. I guess I have some reading to do to help him out Mike0
Try to find someone with a portable SW receiver like a Sony ICF-SW7600G. Tune it to the interference and check that it is hearing the same noise as the Flex display. Then do some walking/ sniffing with the portable's whip antenna. When you get close you'll know it hi hi Portable SW receiver is one the best RFI sniffers a ham can have. Also, watch the timing of the interference. A/C units cycle. that's how I found my external A/C fan noise. And BTW, watch those modern washing machines, I have severe noise on wash day.
It turned out to be a bad power supply connected to radio. Switched it out all is better Thanks all Mike N9DFD0
- 332 Community Topics
- 600 The Flea Market
- 7.9K Software
- 6.2K SmartSDR for Windows
- 399 SmartSDR for Mac
- 263 SmartSDR for iOS
- 247 SmartSDR CAT
- 184 DAX
- 370 SmartSDR API
- 9.1K Radios and Accessories
- 17 Aurora
- 169 FLEX-8000 Signature Series
- 912 Maestro
- 52 FlexControl
- 879 Genius Products
- 317 Tuner Genius XL
- 116 Antenna Genius
- 279 Shack Infrastructure
- 196 Networking
- 137 Contesting
- 730 Peripherals & Station Integration
- 137 Amateur Radio Interests
- 949 Third-Party Software
