VPN now show Radio on SmartSDR PC
iz7auh
Member ✭✭✭
Hi,
I need help, I make a VPN with my HP laptop and my Fritz!Box VFN nerver, I use ShrewSoft VPN Client, and VPN connection work finw, Ping my router at home, ping Flexradio IP, but SmartSDR not Show Radio a windows if empty... any solution? there is a tip to force? on SmartSDR iOS not problem, I make on setting app a force to IP of my Flex, but on Widnows version not possible...
Hi Frank
One tip I have learned is the local IP subnet on each end cannot be the same. For example, if your home network uses 192.168.1.x then the remote local network cannot be the same.
I have set my home network to use 10.4.0.x so I do not run into problems with any remote networks.
Make sure you have these ports open on any firewalls involved: TCP 4992 UDP 4991 and 4992 73, Bob, K8RC Radio Cincinnati0
Dave my VPN work fine, problem is smartSDR and UDP ports0
Then check your firewall and AV software to see if it is blocking the ports. You may need to make an exception for SmartSDR.0
Dave my VPN server is hardware I using a FritzBox 3490 on miniPc running Shrewsoft VPN client I am not sure that problem is firewall because on Windows 10 I disable firewall0
The VPN server or client or both may have a firewall that can block ports.0
Hi, I make rules on fritzbox foe 4991-4992 udp and 4992 tcp to flexradio 6500 disable on minipc windows firewall, but no chance to see on smartsdr app my flex from VPN connection, all other device work fine....0
- 113 SmartSDR+
- 921 Genius Products
- 124 Antenna Genius
