What microphone recommendations for maestro?
Hi Tony,
While not an inexpensive solution, I use the RadioSport RS-60CF headset with M350 electret condenser element. It is using the cable designed for the Maestro which has dual 3.5 mm right angle plugs which connect to mic2 and phones jacks.
I agree the Flex hand mic is very poor in comparison.
I find having a hand mic convenient with the Maestro.
My solution was to improve the Flex hand mic by replacing the dynamic element with an electret element.
I bought the electret element on ebay http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItemVersion&item=152019599810&view=all&tid=1430...
Pack of 10 so I can use them for other projects. I wanted a 600ohm element but couldn't find it so I had to do with this high ohm valued ones.
Then all you need is a small resistor and a capacitor.
The Flex microphone is slightly different, the + and - for the MIC are very close to the switch instead of on the side like in the above picture. The 5v is in the same pin as in the pic above. I tested it just to make sure.
This diagram explains it better.
I used different values for the resistor and the capacitor. Resistor I found the closest one to 8.2k in my spare parts box and for the capacitor I used a 100nF which worked better with my voice and the eBay electret element.
I also put 2 electret elements in parallel to increase gain.
It works great!! It takes 5 minutes to do and you might even have the parts laying around.
3 -
Thanks I had considered replacing the element but am now thinking along the lines of buying a headset0
Maybe the engineers at Flex might be interested in installing a microphone directly into the Maestro?
Here's a candidate device: http://vespermems.com/products/vm1000/ .
Here's where I learned about the product: http://www.bizjournals.com/boston/news/2016/12/09/amazon-part-of-15m-investment-in-boston-audio.html
FWIW - For what it's worth.
Rather than continually purchasing micrphones or constantly rewiring them, I just make adapter cables with an 8-pin Foster connector at one end to match my W2IHY EQPlus processor and then wire whatever plug I need to the other end to match whatever the radio of the month (or year) happens to be. The mic wiring remains unchanged, a Kenwood MC-90 dynamic desk mic, which I happen to like.
Someone gave me one of these the other day, and it works great, people say it sounds just like me. Give it a try, I'll be glad to set up a sked with you so you can hear it. By the way, no RF problems so far.
https://www.amazon.com/gp/product/B00081A2CW/ref=pe_2602570_270154300_em_1p_0_ti
Also in answer to part of your original question...
The term "TRS" refers to tip-ring-sleeve of the microphone (or headset) plug (or jack). TRRS thus means tip, ring-1, ring-2 and sleeve. Starting from the end (tip) of the plug. A good example of a TRRS plug is like that which is on the end of your iPhone/iPad ear buds. A typical Morse straight key will be wired with only a Tip and Sleeve plug, written as TS. And different sizes (diameters) of course. A std. 1/4" plug is also sometimes written as a 6.5mm plug and 3.5mm to represent the 1/8" plug. Hope this helps.
UPDATE: I found an alternative microphone that can be used with the FlexRadio Maestro. I currently own and operate a Maestro “A”, which has an RJ-45 / 8 pin modular that is also used by Yaesu.
The microphone is the Heil Sound PR-10 Microphone Package. The microphone looks like a minature PR-40 with it's own base. The microphone plugs directly into the back of the Maestro via a CC-1-YM adapter (rj-45/8 pin modular) that connects to the 3 pin XLR on the boom end of the microphone. You will also need a CB-1 PTT (1/8” male to 1/4” male interface) cable from the base of the microphone to the CC-1-YM.
It works for me with NO problems and has given me great audio reports
- 388 Community Topics
- 156 SmartSDR+
- 53 Aurora
- 970 Maestro
- 944 Genius Products
